Question about Sharp 13" Tv Model No. 13n-m100b
How to get channel 4
Tried remote control and up down channel button. It goes to 3, 6, 10, 63, and input. It skips channel 4
  • Sharp Master
  • 15,557 Answers
You have to go back to the setup screen and scan for channels. Then you need to have a signal present for channel 4 so that the scan finds that channel. Note that if it is a unit that is not digital then it wont find channel 4 for broadcast. If it is digital and you are hooking something to it like a video player then it wont see channel 4 if the player is not digital.
Posted on Dec 08, 2014
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
How do i change my tv to channel 3? It is skipping this channel and goes from 2 to 4?
Instead of pushing the channel up or down button, manually input either 3 or 03 or 003 to get to ch. 3.
Oct 06, 2009 | JVC Televison & Video
Sony kv-36fs16
Maybe the other channels was skip. check it Menu setting under Preset menu. check other channel it should be skip OFF.
Jun 07, 2009 | Sony KV-36FS16 36" TV
TV stuck on blue video screen
This usually happens when you are on a source that doesn't have a signal such as a channel with no signal or an AV input that is not connected.
You should look for a button that has TV/VCR or TV/VIDEO on it. I've guessing that you've already tried to change the channel but if not try that.
Last ditch effort in that case may be to unplug the TV for a few secouds. Warning- this may wipe out any settings you have entered such as the channel programming (which channels to skip while surfing) but along with that goes the blue screen.
Jan 11, 2009 | RCA Universal Remote Control
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Oct 01, 2008 | Emerson EWF2004 20" TV
Sharp 13" Tv Model No. 13n-m100b Logo
56 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
