Question about Kenmore Refrigerators
How do I move the Kenmore Pro freezer away from the wall to work on the ice maker water line?
  • Kenmore Master
  • 16,010 Answers
Pull it straight out from the wall.
Posted on Dec 08, 2014
What size water line do I run for my kenmore all freezer ice maker
If it's a new in-wall run to it, standard 1/2" is fine. From the wall to the freezer you can do 3/8" or 1/2"
An ice maker doesn't use a lot of water so you can consider it a low demand system. If you're connecting from wall to freezer most hardware stores have premade hoses; just like the water hoses for a washer or a toilet.
Jan 24, 2015 | Kenmore 18.6 cu. ft. Built-In All-Freezer...
Kenmore side by side Model #106.53532300~~~Ice maker stopped working????
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 06, 2011 | Refrigerators
I just hooked up the ice maker to the water line and put the lever down on the icemaker. The water has not filled the ice maker. Is there something I need to do further? The model # is 596.765 73600
  • here are some things to check for, please be very careful and only to this if you disconnect the power supply.
  • 1 Inspect the shut off arm located on the side of the ice maker. This arm should move up and down with a slight resistance when pushing upward. Make sure that this lever is not frozen to the side of the ice maker preventing it from dispensing ice. In addition, if the arm move loosely up and down, then it is broken and must be replaced.
  • 2 Verify that the ice maker is receiving water. Check the water supply valve which is usually located either behind the refrigerator or under the kitchen sink. The knob should be turned all the way clockwise until it will no longer move.
  • 3 Move the freezer or refrigerator out from the wall and locate the water supply line. This line extends from the water supply valve that was previously located. Make sure there are no kinks or twists in the water supply line as this prevents the ice maker from getting water. Also check for leaks along the supply line which will also prevent the ice maker form working.
  • 4 Locate the manual shut off button for the freezer, if it has one. In some models, the shut off button is located inside the freezer door. If this is the case, simply check to make sure the button is switched to the "on" position. Shut off valves are only on some Kenmore refrigerator/freezer combination appliances.
  • 5 Measure the temperature in the freezer by placing a thermometer inside and allowing it to sit for approximately one hour. If the temperature is higher than 17 degrees F, then something is wrong with the main freezer and not the ice maker.
  • 6 Check the water inlet valve to ensure that is allows water to flow through freely. First turn off the water supply at the water supply valve, usually located under the sink or behind the appliance. Locate the water inlet valve by following the water supply line up to where it attaches to the refrigerator or freezer. Turn the plastic nut at the base of the supply line counterclockwise to detach the supply line. Pull the two or four wires of the water inlet valve off of the terminals. Inspect the wires for burn marks or corrosion. If these are present, it means they must be replaced as water is not being fed to the freezer.
  • good luck
    Iain
    May 02, 2011 | Kenmore Refrigerators
    Kenmore bottom freezer refrigerator warming up
    Hi
    There is a definetely leak in the cooling gas.
    Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
    Secondly you are right about the Water Valve... it needs to be changed.
    Regards
    Berry
    Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
    Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
    you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
    Jan 22, 2010 | Freezers
    Ice maker stopped making ice. Now water continuously drips.
    Replace the water valve behind refrig , where the wall water line connects to on refrig .
    Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker not working
    Follow the water line. You will find a control valve like a washing machine has. It's easy to check out and replace.
    Apr 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
    Kenmore
    sounds like your freezer isn't freezing lift up the wire arm on the ice maker to shut it off then put your finger where the ice cubes should be and if the water isn't frozen you may have a cooling problem listen to see if you hear the freezer fan running then look at the bottom of the freezer at the back wall where the vents are and see if they are blocked with frost and reply to me
    Dec 31, 2007 | Refrigerators
    Kenmore Bottom Freezer 596.71103101 Ice maker not working right
    Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
    Nov 13, 2007 | Refrigerators
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    Jude24
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
