Question about Sewing Machines
Hi my thread is looping in a big mess on the bottom of the fabric when I sew. Everything seems to be running smoothly, the machine isn't making strange noises or anything, but the thread is very loose
I have tried changing the needle, changing the tension, cleaning the machine, and re threading everything and nothing works. Please help!
  • Bryan Smith Dec 08, 2014
    If no snag, then the tensions are wrong. You need less lower tension and more upper tension.
    Ensure you are properly threading it as well.
    Master:
  • 373 Answers
Hand operate the machine while looking at the lower bobbin. Maybe there is a rough spot that is snagging the thread as it tries to loop around. If so, then nail file it until it is smooth again.
Posted on Dec 08, 2014
Testimonial: "Thanks so much for answering so fast! I hand operated it and watched the thread and it didn't look like it was snagging anywhere."
  • Deborah Vanderwerf
    Deborah Vanderwerf Dec 08, 2014
    I looked at it again, and it seems I put the bobbin holder in wrong. Thanks so much for your help!
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
Thread looping at the bottom of my fabric on my Elnita 120 Sewing Maching
here is a link for a manual for the machine
http://ifixmachines.com/index.php?page=shop.product_details&flypage=&product_id=1540&category_id=1575&option=com_virtuemart&Itemid=54&vmcchk=1&Itemid=54
try changing the needle--use one that is correct for the fabric being
sewed
the top tension adjustment for the bottom loops
make sure the bobbin is turned the right way in the bobbin case
make sure the top thread has not come off the thread take up lever
Feb 11, 2013 | Sewing Machines
Upper tension is to tight on the izek singer machine we have. Also on the bottom of the fabric the thread is looping up and tangeling.
Loops on the bottom mean the upper tension isn't tight enough. First make sure you thread the upper thread with the presser foot UP. Then do a test seam on the same type of fabric. If you still have problems. Tighten the upper tension a little then test seam again. Keep doing this until your problem is resolved.
Nov 09, 2012 | Sewing Machines
Lower thread too loose
Big loops on the bottom of the fabric is NOT the lower thread. First make sure that your upper thread is correctly threaded with the presser foot in the UP position. Do a test seem. If you still have loops tighten the UPPER tension knob. Do a test seem.
If after several upper tension changes do nothing. Remove the upper thread and take some rather rough sturdy fabric like light weight denim and "floss" where the tension discs are then rethread... and try again.
Oct 14, 2012 | Brother XL-2600
When "locking " a stitch, bottom thread breaks and/ or bunches up.
Make sure you hold thread in back of the lowered presser foot when you begin stitching, and that the needle is piercing the fabric so that the fabric isn't slipping down into the feed dogs (under needle plate area).Hope this helps you out,alexlefebvre.Jimmy
Apr 12, 2012 | Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
My bobbin housing seems to be messed up. I follow all the directions in the manual, but nothing helps. My bobbin stitches are looping on the underside, my machine keeps breaking needles. I'm just trying to...
Ok, if the bottom thread is looping (bottom of fabric) try adjusting your UPPER tension.
Make sure that your thread isn't catching on anything before it reaches your needle, a small snag can cause needles to break.
Jan 12, 2010 | Singer 118 Mechanical Sewing Machine
My machine is skipping stitches when I free hand quilt & the top thread is looping on both the top & the bottom
Make sure you have your thread through all of the thread guides, If I feel I need a little extra tension I loop my thread through the bobbin tension guide on top of the machine, especially if it is a fine or silky thread for decorative work. Make sure your bobbins are wound tight and also threaded correctly. When freehand quilting you should sew at a moderate speed and make sure to move your fabric smoothly with the speed at which you are sewing, you may just have to practice a bit like I did...If none of this works you may need to take your machine in and have the tension set on the bobbin housing itself..
Oct 26, 2009 | Singer 7436 - INGENUITY
Sears Kenmore sewing machine model number 15358 tension issues
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Apr 15, 2009 | Sewing Machines
I have the Brother ls2125i and LOVE the machine...in the middle of sewing, it started making very big loops on the bottom stitch and they do not catch the thread from the needle. Is it the tension?...
Here are some things to try:
Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no matter how much thread you pull, your thread is good. If that your machine passes that test, we can go to step 2. If not, try different spool of thread, do the same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Kent
Mar 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
