Im looking for quick replacement bolts cor the base mount on my tv. Magnavox. 47mf439b/f7
  • 10865 Answers
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
Posted on May 02, 2009
  • 476 Answers
SOURCE: I need bolt to attach the base to the lcd
go to a nut and bolt place, take the base with you, i'm sure they can come up with what you need.
Posted on Sep 04, 2009
SOURCE: IM TRYING TO MOUNT THIS TV AND i CANNOT GET THE
there are screws in the back holding it
Posted on Jan 16, 2011
  • 159 Answers
SOURCE: my tv is a 42
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Posted on Apr 20, 2011
gopakumarg43
  • 74383 Answers
SOURCE: magnavox 42mf439b/f7 screen will not turn on
Set need through check up. It sounds that the digital processor board also need service.
Posted on Apr 18, 2012
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ...
tv.manualsonline.com > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Magnavox 47mf439b/f7
About which part you are discussing about?
May 02, 2013 | Televison & Video
How to hook up sound bar to magnavox television
hi
lprokopy
You can connect from headphones out , one like these:
3.5mm to RCA Audio Cable Adapter
to your soundbar
or
you may need a digital to analog converter
http://www.amazon.com/Digital-Audio-To-Analog-Converter/dp/B0013LWK3A
out from SPDIF ( the back of your TV) and the soundbar
Only if the sound bar does not have a digital input.
Sep 29, 2012 | Magnavox 47MF439B 47 LCD TV
How to hook up external speakers
There is no direct port to hook up external speakers. you have to use an amplifer to get connected in between TV and amp, using an AV cable.
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
How do you hook a pc to magnavox 47mf439b/f7
make sure your tv has a vga connector then run a vga cable from your pc to the tv and change the input on your tv to vga. it's that simple.
Jan 06, 2011 | Computers & Internet
Cant find correct magnovox 47mf439b code to use with direct tv remote
I have the Magnavox codes as listed for my Comcast remote and possibly one of these will work for you. ( 0054, 0030, 0179, 0186 )
I have the same TV as you and 0054 worked for my Comcast remote.
Good Luck!
Mar 22, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
