Question about Kitchen Appliances - Others
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
I've tried using more flour to make the dough easier to work with but it only made the resulting bread too hard.
    New Friend:
  • 30 Answers
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Posted on Mar 03, 2015
  • Terry miller Mar 03, 2015
  • 720 Answers
It should have a ratio somewhere of 500g mix to 320 ml water.
Posted on Dec 09, 2014
How can i fix dough that wont rise?
Check if yeast is old out of date, expired. When making bread most items should be at room temperature unless the recipe calls for milk to be heated to a certain temperature. Follow instructions carefully. Note the differences in Canadian and American flour you will need more American flour if you are using American flour in a Canadian recipe. When making bread the type and or brand of flour will effect the outcome , humidity also affects bread. As to the outcome of bread kneading , resting, texture are something you learn. If dough is to dry add 1 tablespoon of water at a time , if too wet add 1tablespoon flour, dough should neither be sticky or to dry , should feel like silk . Seasons change the affect of how flour works. Drafts also effect dough, when dough is left to rise it should be placed in a place away from drafts and is warm. A well greased bowl large enough so that the dough can double in size this usually takes about 1 hour don't rush this part. Dough should be greased on top so it will not stick to what it covered with. Once the dough has doubled in size punch it once done, either cut into loafs or into buns, place desired greased pans cover let rise again about one hour. Put in oven set at required temperature , set timer for 15 min, check for brownness, if it is not to your liking leave it oven for another 5 mins, bread or bun's are done when they are tapped on top and it sounds hollow take out of oven let rest in pans for about 5 min's, place cooked bread on rack and let cool, do not place on flat surface as the bottom will sweat it needs to have air flow all around it to cool properly. PS remember making of bread is a labour of love, because it lets you take out any anger while you beat and fold the dough, the dough loves you for this and it will give back to you a light and airy texture. Keep on loving.
Aug 04, 2014 | Baking
Panasonic 257 bread and dough not rising
Can you send me the specifics of the recipe you are following? Also please include the type of flour.....all purpose flour, self rising flour, bread flour...etc. etc.
Apr 11, 2013 | Kitchen Appliances - Others
Bread raises to good heights and then falls while baking to half the size. I have made 2 loaves now and it has done it to both. I have new yeast for a "bread maker machine".
Very likely Oven temperature that's too low. This means the dough rises to its maximum, then collapses before it gets hot enough to set.
Try using a little less liquid and/or more flour in your recipe; Might be enough to fix it..
Also try a different program. and/ or Try different recipes
If still happens, return machine as defective.
Jan 01, 2011 | Oster 5838 ExpressBake Bread Maker
Bread cooked beautifully but came out with a huge hollow cavern' inside.
You may be using too much liquid or not enough salt.
Have a quick look at the start of the mixing process, the dough should be firm and tight, slightly sticky but not wet.
You must also use Strong bread flour. All purpose will make a very cakey type of loaf.
Dec 20, 2010 | Breadman TR2200C Ultimate Bread Maker
Dough will not rise
I have run into this same problem. If you add a little more bread flour to your gooy dough it may help. as for the not rising enough maybe your yeast is either to cold or to old.
May 10, 2010 | Regal Ware GL2850 Bread Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Baking gluten free bread in model 5890
good day,
hope this link below will solve your problem.
Set your bread machine program for 1.5 loaf medium crust. I used the gluten-free cycle on the Breadman; if you don't have a gluten-free cycle, I believe a rapid rise cycle will also work.
Check the dough after a few minutes of kneading- it should be closer to a muffin batter than bread dough, soft but not too wet. Adjust dry to wet ratio with a tablespoon of flour or warm liquid, as needed. Humidity influences the dough. As does temperature (your bread will rise higher on a hot day).
If you like a crusty loaf, remove the bread from the pan and place it in the oven at 350 degrees F for an additional 10 minutes- keep an eye on it and don't let it get too brown. It should be a light golden color.
Cool the loaf before slicing for best results.
Enjoy fresh from the oven- the first day (as with most gluten-free baked goods) has the best texture and taste
Read more: http://glutenfreegoddess.blogspot.com/2009/02/delicious-gluten-free-bread.html#ixzz0ZZASptEr
Dec 09, 2008 | Sunbeam 5890 ExpressBake Bread Maker
Dough does not rise
Make sure you are following the recipe very carefully. You have to have the proper type of four, and yeast. Make sure you are using flour that is called bread flour. This type of flour has higher glutent than cake flour. Cake flour would make a heavier bread.
As for the yeast, there is a special yeast for bread machines. Regular yeast would be too slow acting for most bread machines.
Jerry G.
Nov 08, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
Bread falls while baking
Try using a little less yeast or slightly more flour. The dough is either not quite stiff enough or slightly too much yeast.
Jun 13, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
168 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
