Question about Comfort Line Products Spa2Go Inflatable 4 Person 6 Hot Tub Blue
I have fractional spa pump with 1000 watt heater. the spa was on but no water was in it while it ran overnight. did this burn the heat elements out of it and can I fix it?
The plugs were left in. removed plugs and filled pump before starting back up. It sounds normal but not sure if heating element? is blown. If so, can this be fixed? I'm not sure if it is a sealed unit or not. blower works and it is circulating. 1 hp turbo blower Fractional hp circulating pump 120v 1000 w heater
    Master:
  • 373 Answers
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Posted on Dec 08, 2014
Testimonial: "Thanks man. I know it takes a long time at start up to heat, so I'll give a few more hours and see if it heats up."
  • 1,631 Answers
Ditto...
your flow switch should have confirmed that NO water flow was evident and would not have turned on.
If your flow switch failed and the heater did come on, then MOST definitely your heater burned up and the fix is relatively easy.
But waiting hours is not enough time to heat, 1000 watts will take a LOT of hours! Even days!!! LOL
just kidding, but an hour or so, will not be enough
Good Luck
Posted on Mar 10, 2015
What does it mean "run pump for temp" and how do I deal with it? I'm just setting up the hot tub at the cottage and it is taking a long time to heat up. Thanks
the heater element is in the pump housing and needs the pump running so that the heated water is circulated to get it all hot
with no pump operation all that is getting hot is the pump housing area and that will burn out the element
May 28, 2017 | Pool & Spa
How long should a 2007 eclipse spa take to heat up??
Usually spas heat approx 5 degrees an hour. If its been a day or so and your water isn't up to heat, you probably need a new heating element in your spa. Check the voltage at your heating element, and on your topside there is usually a heat indicator light that should be lit. If it has correct voltage at heater and the indicator light is lit, heater burned up. If you have incorrect voltage at heater check fuses for a possible blown fuse and see which pump it goes to, that could be your problem.
Mar 09, 2014 | Pool & Spa
Hot water recover time
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
Jan 04, 2014 | Camco Copper And Zinc Standard Hwd Water...
Hot tub heater not working
Yes, note the manufacturer and watts of the heating element (should be on the heater)
May 27, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
Hot tub won't heat over 86
Your problem is likely the heater element has failed.
The water is only reaching, mid 80's due to friction and heat from the pump. This is an intermediate problem, we recommend calling an spa technician. If you want to read: how to do to test a spa heater element.
Nov 02, 2012 | Pool & Spa
Why does my heating elements burns out every two to three weeks...
The most common cause of heating elements failing are:
1: bad water chemistry. If you water chemistry is not within nominal ranges
@ 2-3 ppm sanitizer
@ 7.4-7.6 pH
@ 70-120 alkalinity
@ 250-350 calcium
Then it has the ability to litteraly eat through metal, which the elements are.
2: Hight water flow. If you are forcing too much water through the heater (every heater manual states maximum flow rates) then it will strip the metal from the element ruining it in short order.
3. Electrolosis. If the heater, pump, and anthing else metal on your pool is not bonded with bare solid 6 guage wiring, then electrolosis is taking place and eating anything metal that the water comes into contact with..
Note: If you have a saltwater spa/pool , this would be a big contributer to your problems, both from the water chemistry part, but especially on the electrolosis.
Jan 24, 2011 | Hayward CSPAXI11 11Killowatts Electric Spa...
I have a Heritage spa that has a fault code of FLO on the pad and also it is not heating up.. Are these related and what is the fix... Cheers Steve
All spa's have a circulator pump. This pump works in conjunction with your heating element. The pump automatically turns on when the heater does to circulate the newly heated water. If the pump fails, the heater will not kick on as a safety measure so you don't burn out the heating element. It sounds like your circulator pump has failed. On many spas, this may also be related to a pressure switch failure. I hope this helps. It should at least give you a place to start.
Jan 03, 2011 | Heritage Pool & Spa
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
Comfort Line Products Spa2Go Inflatable 4 Person 6 Hot Tub Blue Logo
363 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
