SOURCE: Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
SOURCE: Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup.
[from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
SOURCE: philips DVP3350
hello mate here are the instructions. First you have to download "ZORAN.ZIP" and extract to desktop you will now have a
file which name is "LG36868.IMG"
2. Then You have to burn this file to cd>
3. Insert the CD into player after burning the CD.
4. Then the region management menu will be shown.
5 If you input '0' and press 'pause key' by
Remote Con. Then Code free is done.
Download the ZORAN.ZIP
http://www.divx.pri.ee/index.php?name=Forums&file=viewtopic&p=387#387
please leave rating if you find this usefull thanx
SOURCE: Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
SOURCE: Want to unlock my philips dvp 3310 s
it's very easy...
open tray, no disc in it, enter with remote 9999 followed by 0 and it's region free!!!
What if you're DVD doesn't have a preference page to turn off the region area
