Question about RCA ViSYS 25425RE11 4-Line Telephone with Digital Answering System, Blue backlit LCD, Caller ID/Call Waiting, Enhanced full duplex speakerphone, 16 One-touch speed dial buttons, Hearing aid compatible, Headset jack, Switchable data port, Desk and Wall mo
I have an RCA phone with multiple lines. Lines 1 and 2 work fine, but line 3 says "plug in line" at all work stations. I have a fourth separate line that works just fine. Line 3 is a separate numbe
All lines have been checked, unplugged and plugged back in already.
SOURCE: intercom
make sure each and every phone has its own ID. That solved problems for me for all but one phone.
Posted on May 22, 2008
  • 4 Answers
SOURCE: 2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Posted on Aug 14, 2009
SOURCE: Have an RCA executive series. the light for the
I have an RCA Executive Line 4-line phone. I was away for a week, and came back to find the speakerphone when I dial out is significantly muffled on some of the lines (people that I am calling complain of noise on the line). If I take it off speaker, the quality on the handpiece is normal. First, I thought it was the batteries, so I replaced them. Didn't change. Is there a reset? Is the phone (base) after less than 1 year defective?
Posted on Mar 29, 2010
SOURCE: RCA 25414 message light... doesn't
Fix for message light blinking on ECA 25414. Many folks have changed phones or bought used phones to find the message light blinking on the phone especially on lines they don't have. That is what I found on used phones. Leave yourself a message on any phone. Now plug that line into the correct jack in the back for the line that is blinking in other words line 1 or 2 or 3 or 4.. Call the number from the line you plugged in and retieve and delete that message. Hang up and shortly the message light on the phone should go out.
Posted on May 18, 2010
greg411
  • 45 Answers
SOURCE: VoIP setup with 2 lines - Both lines pick up on outgoing calls
It does not matter that you have VoIP or traditional telco with the problem you are describing. I think you have a problem with the adaptor or a wire. Check the connectors and the plugs in the phone to see if anything is bent.
Posted on Jul 21, 2010
Hi. I have a new 4-line phone (RCA 25414-RE3) and it is connected like the manual says. But it is not separating line 1 from line2 or line3 from line 4. They are both on lines 1 and 3.... can you help
There are a couple of problems you may have.
First, the wall jack may not be wired correctly or the wire you ar eusing is a single line wire.
The easiest to check is the wire, look at the plug and see if it has 4 copper leads. If it only has two in the middle two slots then it will only connect line 1. If it has 4 copper leads then it should pass both lines 1 and 2 (or three and four). The middle leads are line 1 and the outer two are line 2.
If the wires all check out then you may have a wall plate that is not wired for multiple lines on the single wire. That will require a technician coming out and rewiring the plate. There are also adaptors available at Radio Shack that will combine two lines to one wire if you have both lines on the wall plate.
I have a blog on 4 line phones if you would like other tips about them. Go to the tag cloud and you will see 4 line phone.
Dec 03, 2011 | RCA 25414RE3 Corded Phone
Line 1 and two not splitting
You can find the combiner at Radio Shack Model: T07843 ' Catalog #: 55034722. It may only be online not in the stores.
Oct 14, 2009 | RCA ViSYS 2-Line Speakerphone
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
I have 6 of these phones. No problem for a year or so, then one phone got the message light stuck on. Tried some online suggestions without success. Powering down etc. failed to fix it so I stuck a piece of tape over the led.
A couple of weeks ago line 2 failed (externally) and ATT sent a tech out who repaired it and also cleaned up the line. When the line came back, all 6 phones had the message light stuck on!
Talked with the tech here and with the ATT support and nothing worked. Eventually the tech here left as it was not a line fault - but he said he would leave the problem open.
That evening a young ATT guy called. He tried a number of different settings and changes - he was really determined! He called Kentucky and Minnesota and part of the advice was "give up and don't call the customer back"!
Finally he found a configuration option in the central office switch (exchange) for the line called CWMI (Call Waiting Message Indicator). Apparently this option was originally active but was changed when the local trunk was upgraded to fibre over the last year or so.
Once he enabled this option (we have call waiting and caller ID on call waiting on this line), the message lights on all the phones turned off and have worked normally since (10 days), including the one that was "broken" for over a year!
I really credit the tech with persistance on the issue.
Hope this helps someone else out there.
Regards, Hugh
Jul 03, 2008 | RCA 25414RE3 Corded Phone
Intercom
May 01, 2008 | RCA 25414RE3 Corded Phone
Phone connection for Lucent 854
You can get a splitter for it which will then divide that one phone jack into 3 out or 4 out which ever you need. the only problem that you might run into is how close the phones might be to each other. Otherwise there isn't much other ways around it with only one phone jack.
Mar 31, 2008 | Lands Phones
Cross talk
The easy way is to buy a radio surpressor. You can find them at Radio Shack, I think. Unless you live very close to a radio station you probably have a ground on your phone line. this can happen either inside or outside you business. Also if you are using a long mounting cord, 25' and up this can act as an antenna and cause radio pick up. I would try to detremine if your problem is on the phone company lines or inside your business.
the question said cross talk, are you hearing the other lines while you are on one line? If so you may have inproper wiring inside your building. Multiple phone lines must be on twisted wire. If two lines are parrell for any measurable distance they will bleed over to the other line.
Jan 29, 2008 | RCA 25414RE3 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
RCA ViSYS 25425RE11 4-Line Telephone with Digital Answering System, Blue backlit LCD, Caller ID/Call Waiting, Enhanced full duplex speakerphone, 16 One-touch speed dial buttons, Hearing aid compatible, Headset jack, Switchable data port, Desk and Wall mo Logo
56 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
