Question about Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
Rethreading, changing needle according to type of fabric being sewn, checking for lint and dust,
  • 43 Answers
Not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Posted on Dec 09, 2014
Testimonial: "hi. thanks for the answer, but i've definitely got it all threaded up correctly with the needle the right way"
  • Lizzie51 Dec 09, 2014
    Is the bobbin the right size? 44444
  • philly
    philly Dec 09, 2014
    it's the bobbin that came with the machine, so i assume so?
I have a Pfaff hobby 1200. When I try to quilt ( it is on an Inspira frame) it sews fine on the top but the bottom side is all loopy. What are the correct tension #'s I can use? I use cotton thread.
It could be a variety of things. Be sure you are using a brand new sharp needle (try a topstitch, embroidery, or microtex needle on woven cotton). Be sure the needle eye is large enough to accommodate the thread weight. Different needles have a different scarf (the groove that is on the back of the needle that runs up from the needle eye). A larger scarf will protect the thread and keep the thread from hanging up on the fabric when the needle is withdrawn from the fabric.
http://www.schmetzneedles.com/all-about-needles/
Also, the upper tension may be too loose if it is still showing loops under the fabric.
Another cause is the fabric being stretched too tight on the frame causing trampolining.
http://www.kimmyquilt.com/tensioning-the-quilt.htm
Frame Quilting
Nov 25, 2016 | PfaFF Sewing Machines
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Birds nest under fabric
try a new needle
always keep a check on the thread take up lever, because sometimes the thread will come off & it can jam the machine up
clean under the needle plate for lint or loose thread & also the bobbin area
always check to make sure you have the correct needle for the fabric your sewing
Aug 05, 2011 | Singer 5062 Mechanical Sewing Machine
I have a metal spernova child's sewing machine. I have threaded it, but it keeps jamming up. It doesn't create the chain stitch on the fabric. What am I doing wrong??
put in a new needle
clean under needle plate for loose threads or lint
clean bobbin area for same
check the top tension to make sure it correct for the fabric
make sure its threaded correctly top & bobbin
make sure the top thread does not come off the thread take up lever
Aug 03, 2011 | Necchi Sewing Machines
Trying to sew curtains!!!! Been testing the machine on a swatch of fabric and it seems to be working but then when i turn the fabric over the stiching is all loose and loopy. Is the bobbin tension the...
check both upper & lower tensions
also check your needle to see if it's bent-roll on a flat surface to see if it rolls correctly
if the needle is blunt-it makes a popping sound when it penetrates the fabric
also check the bobbin area for lint & loose thread-some fabric produces more lint than others
make sure the bobbin isn't warped
make sure that the bobbin is correctly in the bobbin case & that the bobbin case is correctly inserted in the machine
Sep 02, 2010 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
129 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
