I have a Toshiba CT-9946 and I bought an RCA flat digital antenna. They are connected properly and I am still unable to Receive any signal... Any thoughts??
    Master:
  • 373 Answers
Try placing the antenna on the roof and see if you get signals that way.
Posted on Dec 08, 2014
  • 718 Answers
SOURCE: Toshiba 36
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Posted on Mar 05, 2009
  • 58 Answers
SOURCE: I have an rca flat antenna. June 12 I rescanned
you probably need a digital converter box
Posted on Jun 15, 2009
caroldon
  • 17130 Answers
SOURCE: hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Posted on Nov 01, 2011
spr1949
  • 1182 Answers
SOURCE: Can't Get Antenna to Work
Try changing the input device to something you are sure, works such as a DVD player. If it works, check whether the transmission is compatible with the system in your TV. Go to menu and select the correct system such as PAL/Secam etc.
Posted on Aug 01, 2012
skywavebe
  • 1258 Answers
SOURCE: My Toshiba flat screen is not picking up the local digital channels
As an past Radio Engineer I feel compelled to tell you that the conversion to HD in FM and TV signals did not do all of us a favor.
The coverage pattern of stations has decreased to the level of about 70% due to this new advanced technology. I think what your real problem is comes from a misunderstanding of what a HD TV signal must be supplied from. In my house as an example which is 21 mikes away from Chicago and the Willis building where a lot of TV signals are from, the need to put up a new higher gain $100 HD TV antenna was required. You can get such antennas from Antennadirect web site. You will also require a length of high grade 75 ohm coax cable- I bought the high grade Digital TV cable from Gepco International with a 3 GHz bandwidth and also distribute the signal to a number of TV's either with a Wineguard or Blonder-****** distribution amplifier.
My antenna is mounted near 30 feet off the ground. Places like Radio Shack may sell these kinds of indoor TV antennas but they are depending on the lack of knowledge of the people buying them to sell the product. It also depends on how far you are from the source of transmission. If you are 5 miles in a high rise building facing the transmission tower, you might have luck with an indoor antenna, if you are 20 or 30 miles away from transmission you might have to go to more elaborate measures to get a signal down to the TV. There is no magic to it just a need for a person who understands the signal levels and what is needed. I spent time as a Chief Engineer for 4 Radio stations in Chicago as well as was involved in a FM HD installation or two.
See if you can find a Television shop that you can ask questions about your installation. They may be able to help you mount a roof antenna if you can not do it yourself.
Posted on Aug 11, 2012
I have a Toshiba older TV that doesn't have HD digital converter box I bought a leaf ultimate antenna do I still need to use the converter box with this new antenna
if the tv does not have a built in hd digital tuner you need a Hd digital converter to analogue converter. What you need to be careful about is the available inputs on the TV if it only has AV in then you need a converter that transmits out RCA video or an analogue tv channel on RF the tv can tune into. Some of the new converters have HDMI out so if TV does not have HDMI input it won't connect. The antenna would go into the converter. Not sure how much signal you need you may need an rf amplifier if the signal is poor in your area.
Jun 01, 2015 | Toshiba Televison & Video
I havce installed the digital converter box and everything seems to be okey. I get the menu page, and do a channel scan, which brings up no channels. With the converter turned off, I get a cable signal...
1. If you are using the composite video output, double check that your antenna is connected to the converter's antenna input and not the output.
2. If you are in a remote area that gets signals through translators, there might not be any digital signals to receive.
Is the antenna connected to the input of the converter box? There should be a screw on connector on the back, the antenna connects there.
If you have the antenna connected properly, have set the conveter to scan for channels, and you were able to watch TV with the rabbit ears before you got the box, the box may be defective....!!
Thank you!!!
PLease post back for further assistance..
Regards!!...
Jul 31, 2008 | RCA Televison & Video
The TV is a Toshiba flat screen the remote is a Toshiba CT-9854I need the code so my TV will work with an antenna
Antenna reception is no longer available since the nationwide conversion to digital signal transmission.
Apr 01, 2015 | Toshiba Televison & Video
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
I have a 32" Toshiba 32AV500U 32-Inch 720p LCD HDTV along with a HDTVi VHF/UHF HDTV Indoor Antenna. I purchased the TV and antenna about a year ago. I am unable to get any digital TV, only analog. I was...
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Jun 20, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Jan 03, 2009 | RCA 20F420T 20" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
