Question about Denon Audio Players & Recorders
Can I get Chromecast to play thru my surround sound?
I have Chromecast on HDMI4 of my tv. My tv is HDMI to the receiver. There is no HDMI4 option on my receiver setup.
  • 757 Answers
If your receiver has an HDMI input that you are connected to from an HDMI output of your TV; then yes you can listen to it in surround sound.
The HDMI input that you are using on your receiver must be designated as a TV input if it has the capability of being "assignable" in your receiver setup options; or otherwise just connected via HDMI on the rear or front panel of the chassis on TV inputs section.
Once the proper connections are confirmed, select your receiver input to TV. The TV output mode must be set to HDMI; or you will not get any sound or picture if that is the only connection. You'll have to refer to the receiver manual on how to do this if the output mode does not select automatically as I do not know what gear you are using.
If you have your speaker setup in a 5.0 or 5.1 setup; depending on the decoding capabilities of your receiver; you should be able to get audio through each channel in a variety of ways. Refer to your receiver manual for the decoding format compatibility. The decoding may also be performed by your TV as well.
Posted on Dec 10, 2014
  • lottylee8 Dec 10, 2014
    I have an HDMI (3) that goes from TV to receiver. That's how I get DVD sound. I tried to assign the TV HDMI3 on the receiver but it says the TV has no HDMI? Husband got the setup. Geeksquad installed. I'm still trying to learn...
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
SOURCE: HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Posted on Feb 24, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
Pioneer elite. get CEC100 error. which says that "the device cannot be operated. please check the connection"
I have a Pioneer PDP-LX5090, Kuro Flatscreen TV, connected via HDMI4 on a Pioneer AV-receiver VSX-LX60.
By connection a Chrome cast on one of the HDMI ports of the AV-receiver I got the same CEC100 error with the same message "device cannot be operated. please check the connection". By disconnection the Chromecast from the USB current feed, the problem dissapeared. Hope this can help you.
Jul 01, 2017 | Pioneer Televison & Video
HDMI flashing screen on Onkyo TX-SR674 receiver need advice on how to solve this problem
Hi Zach, you can try the following reset as this might be a glitch in the processor.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Feb 21, 2015 | Onkyo TX-SR674 Receiver
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Im running my audio thru the optical audio to my stereo... but only some channels will come thru... I figured out that only the digital channells will play... is there a way that I can get the analog...
No, the digital coaxial output on the tv will only output when digital sound is being utilised. So that normally is HDMI or if using aerial antenna to receive local ATSC signal.
Aug 17, 2011 | Coby 40 TFTV4028 LCD TV
How do i hook up mt audio speakers to my tv for surround sound? klh 403
If I understand correctly form your question,you can not hook them unless your TV has 5.1 surround sound amplifier built in...Does it ? I doubt so..
in order to get a surround sound from your TV you need a 5.1 /7.1 DVD/Receiver and you can connect your TV to listen it thru Receiver ..Here is how you can do it..
** connect "Audio Output " as either :"2xRCA jacks"or "Optic cable output" or "HDMI "connector " of your TV ,
** to "RCA input jacks " or "Optic Cable input"
or if you have "HDMI input" of your DVD/ Receiver
** than just switch to respective mode on
There you go..your Tv sound are on the
DVD/receiver as SURROUNDING SOUND .
will come thru your
Receiver
Take care and please
Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 06, 2011 | Audio Players & Recorders
Need instructions on how to make my tv & playstation run through surround sound all the time
Hi,here is the possible solution......
** you need to connect "Audio Output " as either : "2xRCA jacks " or "Optic cable output" or "HDMI "connector " of your TV ,
** to "2xRCA TV/DVD/AUX input" "Optic Cable input"
or if you have "HDMI input" of your Receiver
By this means ,whatever you watch and or play on the TV,sound
will come thru your
Receiver
continue f
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
242 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
