Question about Leisure Genuine Beko Belling Flavel Stoke Cooker Indicator Lamp Gen - 165955702
Oven knob is broken where do I get a new one
The shaft on the right hand side for the oven is broken I would replace as I can't use my oven. Thanks
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
The stem/shaft that holds the oven knob seems to be broken--the knob turns but does not turn the shaft. Is this a repair an amateur can do and what part do I need?
first pull the knob off the shaft and check to see if its broken where the shaft is supposed to lock-in if so u jus need a new knob. if not you have to pull the panel off the stove and replace the shaft this shouldnt be too difficult either way.
Jan 24, 2011 | Viking 27" Professional Select Built-in...
The right hand oven lights, but no matter which gas mark setting you select, the flame does not rise to increase oven temperature, but stays on pilot settings
the flame needs to be adjusted there's a small screw right inside of the shaft where the knob goes. Pull knob off and there should be a screw inside that u shaped shaft. Turn the burners on and set the flame accordingly.
Dec 16, 2010 | Rangemaster 110 (Gas) Kitchen Range
The right hand side of the main oven has broken
You have not given much information to go on, but I am assuming that you mean the door hinge has broken.
If it is a drop down door, then you will have to replace the hinges as a pair.
If it is not the door that is the prob, then I need more information.
Thanks
Please rate my comments.
Nov 22, 2009 | Stoves 720EF Electric Double Oven
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
My delonghi toaster oven knobs broke! as
Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Whirlpool Generation 2000+ oven
Yeah just turn the left hand knob to the one setting which isn't a cooking function - I think it looks a bit like a dash - and then power up as normal on the right hand knob.
It happpened to me but you get the hang of it and it's not a fault.
Sid
May 18, 2008 | Ovens
Leisure Genuine Beko Belling Flavel Stoke Cooker Indicator Lamp Gen - 165955702 Logo
43 people viewed this question
Top Leisure Dishwashers Experts
Are you a Leisure Dishwasher Expert? Answer questions, earn points and help others
