Question about Home
How do you stop a power flush toilet from constantly running?
We had to turn off the water main recently to fix a leaky spigot in the laundry area. When we turned the main back on, it wouldn't quit running. Please tell me this is something simple.
    Master:
  • 373 Answers
You'll have to see if the water is leaking past the flush stopper or into the overflow tube. The tube is the little pipe where water drains if the tank is filled too high. The flush stopper is a rubber flapper mounted on the bottom of the overflow tube. If water is running into the tube, then the flush valve may be stuck, so shake it up and down (gently) and hopefully it will be freed. If water is not running into the tube, then reach down and try to seat the flapper stopper to see if something was lodged there to keep it from seating all the way. Would be a simple fix either way.
Posted on Dec 08, 2014
Our toilet systern is constantly running it won't shut down
Faulty flush valve or leaky flapper
Nov 30, 2017 | Home
I get water out of my spigot and bathtub but nothing out of my faucets
Your aerators are probably clogged. The reason you still get water out of your tub and your spigot is because they have no screens to clog.
Have you had your water main shut recently or have the hydrants in your area been flushed? Both of these conditions can cause screens to clog. Remove the aerators, flush the lines and clean the aerators. If you still have no water, your stems and cartridges may also be clogged. They must be removed, cleaned and/or replaced, and the faucets flushed. If you have well water, your well may not be developed enough and is sucking up sand. This is usually not a concern if it's not a new well, or if your well hasn't been worked on lately.
Mar 09, 2017 | Plumbing
How to fix a leaky toilet
    1. Turn off the water at the shutoff valve, flush the toilet and hold down the handle. There may be a little water left in the bottom of the tank, but don't worry about it. Wipe the flapper seat with a clean cloth to make sure it's free of debris, and check it for cracks or splits (Image 1).
      How to Fix a Leaking Toilet ' how-tos ' DIY
      www.diynetwork.com/how-to/.../how-to-fix-a-leaking-toilet DIY Network
    Feedback
  1. How to Fix a Leaky or Runny Toilet - This Old House
    www.thisoldhouse.com > ... > Toilets
    This Old HouseA toilet that leaks or runs is an easy homeowner fix-if you know how to diagnose the trouble. ID parts and problems with this handy guide, and hit the hardware ...
Dec 26, 2015 | American Standard Home
Both of my Caroma toilets constantly "run",water is trickling constantly. How to stop those leaks? labels on toilets say: Caroma C Velle 305 EL SNV PAN made in PRC. Maintenance people from the...
Constant running can be due to a defective fill valve or faulty flapper. Try replacing either or both before discarding the entire toilet. One other possibility is that poor design results in poor operation.
Aug 07, 2017 | Caroma CARAVELLE270ADAW-EL Caravelle...
Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Aug 01, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Home Logo
140 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
