Question about Roland Music
A rOLAND G6 A PRESONUS 16.02 A MPC500 AND A MAC TO WORK WITH PRO TOOLS. I need a diagram and what wires to buy so it works all through pro tools 9
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
You will need a usb mixer or some other usb audio interface. Most likely whatever you purchase will come with installation instructions. Make sure whatever you get has more inputs than you need for future expansion.
Posted on Dec 21, 2014
2 Suggested Answers
  • 5603 Answers
SOURCE: I need the schematics for the Roland CK-60 amp or
This MIGHT be close to your unit... it is for the KC-100... they often use the same circuitry.
http://elektrotanya.com/roland_kc-100.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. There may be slight variations but these amps are simple enough to troubleshoot. USE the old trick of putting an incandescent lamp of say 100 watts in series with the power input to act as resetable fuse and save fuses when powering up after a repair.
Posted on Apr 29, 2011
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
Where can I get the Driver for a Roland RD-300sx to use with Mac OS X v10.7.2
http://www.rolandus.com/products/productdetails.php?ProductId=655
that driver
http://www.rolandus.com/support/downloads_updates/eula.php?FileName=DPiano_mx7d_v100.zip
They only have it up to 10.7.0 But it should work fine with yours.
Feb 14, 2012 | Roland Music
Hi, My Roland Fantom G6 keyboard has an accident and the analog output is dead. I ask you if it is a possibility to find the entire Jack Board for replacement. It is named: FANTOM-G6 JACK BOARD ASSY...
Does the headphone jack work? Replacing a whole board would be expensive and the problem could be elsewhere. What was the accident? If large signals were driven back into the audio out lines, probably the output driver chip is fried... They likely use a common 8 pin dual op amp as the driver and the part costs 50 cents. It takes a little care to replace it as it is likely surface mounted. I am looking at the audio/jack board for a G-600 and there are a pair of transistors for some testing they do that could also be fried and might be the whole problem if the G-6 uses same or similar circuitry. The Fantom X6 uses very similar circuitry... Download service manual here:
http://elektrotanya.com/roland_fantom-x6.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links. On page 57 of 66 you will find the audio drivers at the right. They use little dual op amps M5218APF which probably are available someplace, however probably 4568's would work fine and are readily available. If you drove high voltage into the audio outs, I suspect first that the RF bypass caps such as C203 on the above schematic shorted. Simple to replace... pennies apiece... The test path transistors such as Q37 may also be shorted... Next would be IC18... While this circuit may not be the exact one for the G6 it probably is CLOSE as the several Rolands all seem to use similar circuitry. Regarding system SAFETY... Make sure ALL and I do mean ALL equipment interconnected including mixers, powered speakers, keyboards, etc. are powered from the SAME receptacle or power conditioning module to avoid accidents. Also for keyboards sent to mixers, USE DI boxes please! These protect against ground loops and these accidents.
Sep 13, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
I would like to connect my fantom g6 to logic and be able to play the sounds from logic through my fantom and record into logic.
If you hook it up with the USB cable Logic should recognise it. You may have to select it in the Audio Preferences as your Audio Interface.
Jun 30, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
My roland fantom xa turn on but dosn't log in it just show something like roland fantom xa in continue slide show
when i turn on my roland xa it's going on but it show on screen xa fantom and it gonig hang what i do
Feb 25, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
I have a Fantom S keyboard. I have to press the the F above middle C a lot harder than the other keys to get any sound. How can I repair this?
Hard to say as they are a very complex machine. However have you tried a factory reset - check the manual - its a certain key/button combination. You will losse any special settings but glitches are often solved by a reset. Good luck Bruce
Feb 13, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
I was looking at a 2nd hand KR 103 to buy. If while playing notes the damper pedal is pressed all sound is muted. Is there a function switch or something that needs swiching on to get it to work? The...
Please note that ROLAND equipment USUALLY uses Normally closed (electrically) damper pedals for their equipment. Most other brands use normally open ones. If you are using a non-Roland pedal, that is likely the problem.
SOME PEDALS require opening and changing a wire (involves soldering) to match the unit you are plugging into. A very few have a switch on them to allow changing polarity.
A few synths, like the Yamaha Tyros have a built in setup screen where one can select the polarity of the attached pedals.
Sep 23, 2010 | Roland Dp 2 Damper Pedal
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Roland Dp 2 Damper Pedal dont work
I'm 90% sure the pedal is shot ... It could be the switch ... Open the thing up (If your confident) and look to see if a wire has come loose ... If no wires are loose then try another working pedal with the keyboard.
If it still won't damp then there is a problem with your keyboard and I do not suggest opening up one of those ... I used to repair sockets and keys on those for a local boys school and there are full of things that can break if not opened properly,
My suggestion is getting someone in to repair the keyboard if its that ... If its the pedal then either get a new one if you don't want the old one repaired ... Or repair it yourself (pretty easy if its the wiring ... fiddly if its the switch but only attempt if your confident and have the proper tools).
Apr 23, 2009 | Roland Dp 2 Damper Pedal
Music Logo
42 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
