Question about Welding Tools
I have a HEL p-6 code on a xmt 304 how do I fix it
Code HEL p-6
    New Friend:
    Problem Solver:
  • 6 Answers
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Posted on Dec 09, 2014
Misfire code 304
Here's a link to some help on your P0304 code. P0304 OBD II Trouble Code
Dec 07, 2015 | 2001 Mitsubishi Mirage
2003 sorento 3.5 cranks won't start code 300 302 304 306
The code 300 is a Random/Multiple Cylinder Misfire....a 302 is Cylinder # 2 misfire detected. ..and the same for 304 and 306..being 304 is cylinder 4 misfire and 306 is cylinder 6 misfire...All these at the same time normally is a faulty coil pack..,and or faulty coils...spark plugs.,plug wires.....It should be running horribly or barely ....However it could be internal losing compression.....It could just need a good tune up.....Disconnect battery before changing coils,wires..,or plugs in order to clear the fault codes.....
Feb 17, 2015 | 2003 Kia Sorento
Can a tune up fix the problems for an 03 ford explorer that has codes p0113 and p0304?
The 113 Code is a high temp for the incoming air which can be a bad IAT component or wiring associated with it. The 304 Code is a misfire in #4 cylinder.
Sometimes 1 problem causes another and if you work on the IAT sensor, wipe the memory Code, and restart the vehicle the 304 may stay off.
Oct 14, 2013 | 2003 Ford Explorer
Code p0316
Code 316 is an extension of your Code 304. 316 means its misfiring in the first 1000 RPM's and 304 means number 4 cylinder is the problem cylinder.
Could be a bad wire, coil, or sparkplug.
Jul 08, 2013 | 2009 Ford F-150
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
406 pin code number
FX35 PİN CODE ŞAŞİ NO JNRAS08W15X203775 PİNREAD 3BF10
ali.akkaya@nissan-bayi.com
Apr 02, 2009 | 2005 Infiniti FX35
Welding Tools Logo
125 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
