Question about Frigidaire Kitchen Ranges
The oven light pad switch does not switch off the oven light, any ideas other than a malfunctioning switch?
1.turned off main breaker for a possible reset 2. pushed on/off pad switch several times with no results, light remains on.
    Master:
  • 706 Answers
Switch is bad. Isolate and check it with DVOM for continuity.
Posted on Dec 09, 2014
Power but blank screen
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Jan 21, 2013 | GE Microwave Ovens
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
My Whirlpool MH6150XHQ OTR microwave is dead. Checked circuit breaker and outlet with no problems there. Can't get any power- light won't turn on, nothing on display, etc. I'm hoping there may...
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html?utm_source=emails?utm_medium=email?utm_campaign=2011-10%2BHow%2BA%2BMicrowave%2BWorks%2BVersion2&utm_medium=email&utm_source=emails
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Oct 19, 2011 | Whirlpool MH1150XMQ Microwave Oven
We have a convention microwave oven. Model Jmc 243 owp01. Only 2 monts old. The control panel buttons are not lite and do not funtion however the light comes on when the door is opened so the power is...
Possible that the door switch must be checked as this safety switch must latch the power to the main board to set the program and timer. However if the pads are not working then the customer pad, the flexible strip or the main controller board can be faulty that is not making the program controller active.
Mar 13, 2011 | Jenn-Air Microwave Ovens
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Oven control, possibly thermostat or oven selector switch
my dacor ER36G oven will not ignite. The top range works perfectly. When I turn on the oven, I don't even hear the gas or the ignition sequence as I used to. The heat preset light just blinks and the oven will not engage. I have reset the circuit breakers just in case, but nothing works.
Dec 07, 2008 | Whirlpool Kitchen Ranges
Possessed Oven
I found a new touch panel (or membrane switch pad) for < $166 at http://www.myapplianceparts.com/ . The person on the phone at this company was very pleasant and immediatley confirmed that they had 10 of these in stock. This suggests to me that more than a few of these have gone bad. Luckily, they are very simple to replace if you are willing to turn a few screws and carefully pull of the electrical connectors. I dissasembled mine in 20 minutes, got the part number (#62682B for my ECS130), and found best price in 20 minutes.
Oct 16, 2006 | Dacor ECS136 Epicure Stainless Steel...
Kitchen Ranges Logo
53 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
