Question about Husqvarna Viking 1
Having problems, lights flashing can not set
Is there a reset button
  • loosenut Feb 09, 2015
    Hi Mike Wicklund, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model do you have? Have you discussed the problems with a authorized Viking repair dealer?
My mach. will not run/is there a reset button?
no rest button perhaps the manufacturer is the place to look for warranty service
Dec 01, 2015 | Sewing Machines
I am having problems with my decorative stitches. If the decorative stitch needs the "S" foot, the stitch does not sew correctly. Is ther a way to correct this? A reset button or something?
Check the manual - are you using the settings recommended for the s foot? Are you using the proper thread? How about the tension 0 is it properly set for the size and thickness of thread being used?
Jul 24, 2015 | Husqvarna Designer I
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
My brother pc-2800 stitch length button won't light up so I can't adjust the stitch length. Is it worth having fixed?
you might call a repair shop and tell them the problem and ask
them how much it would cost to have the machine repaired that
way you can decide.
Feb 09, 2013 | Brother Sewing Machines
Having problem setting machine for a regular straight stich, what is the setting?
It should be the first setting on the switch pattern button - either A or 1.
Oct 09, 2010 | Singer 2732 Mechanical Sewing Machine
While winding the bobbin my machine stopped threading and all the lights on the front started flashing. I turned off the machine and turned it back on and it did the same thing.
Turn the machine back on, slide the bobbin winder all the way over to the left, and push the reverse sewing button 3 times. That should reset the machine.
Sep 25, 2010 | Singer 7462 Mechanical Sewing Machine
I can't seem to get the buttonhole attachment to work. I do not have a manual, and am doing what seems right - but it's not working. The attachment carries the button in the back. I've set the stitch width...
I am so excited to share this with you. I was having the same exact problem and I found the solution here: http://kraftykuka.blogspot.com/2008/11/benjamin-button-hole-maker.html
the answer was pulling down the button lever! i hope it helps you too!
Oct 16, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Timing
That needs a repairman because you have to reset the gears, if it is still having the same problem take it back to the repair center and they should fix it again for free because they did not solve the problem. I am sorry to tell you but those machines have been nothing but headaches to my customers, many have just bought new machines (our shop sells Brother and Babylock).
Jul 03, 2009 | Singer CE-200 Quantum Futura Computerized...
My machine is giving me an error 88 and keeps flashing fast when I turn it on.
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Feb 15, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
88 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
