Question about Speed Washing Machines
Flashing spin speed lights
After moving , spin speed lights flashing ? Not working. Please help !
Did you check you have spin speed set to highest and not to no spin???
if this doesnt help you need to then look to motor brushes replacment or filter/waiste blockage {partial can cause this at spin time} check your outlet system is clear past the connection too it
Posted on Dec 08, 2014
Cmt scooter moves forward or backwards then shudders a little then stops first light flashing on panel please help.
Sounds like the throttle pot is bad and will need replacing, try changing speed level and try again. if it works then speed pot will need replacing. Scooter Doctor App
Aug 19, 2016 | Health & Beauty
I have s tecnik washing machine that shows flashing lights on start button along with flashing lights on 800 rinse speed and rinse and wash, I have cleaned out the filter which was blocked but can not get...
plug machine in
turn timer knob to 6 o'clock position
press and hold spin speed button
turn timer knob 1 click clockwise
release spin speed button
now turn programmer knob to off wait 5 secs and turn on
I had the exact same issueI
hopefully it will work but you may have to repeat a few times and some engineers say it only works with motor unplugged but I have not found that.
Apr 07, 2014 | Tecnik Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
P0720 speedometer and car speed problems
if it worked for a short time then check the wiring around the sensor you would have moved them around changing the sensor
Aug 12, 2012 | 2002 Ford Escape
I have kemark 19lcd45d2 tv dvd stopped playing any times of dvds it is just over 1 year old could u help me plz.
have you tried cleaning the optical lens? if so, did you notice if the cd is spinning? just follow this simple steps.. (1) check if the dvd is spinning while playing... or check if the optical lens is flashing while playing.. (2) if the dvd is spinning slower than the normal speed the reading process is affected. so which mean the motor playback is the problem... (3) check if the optical lens is flashing... if not check if the ribbon wire is broken... if not the optical lens ha to be replace.. (4) if the dvd is spinning too fast than the normal speed or double the speed than the normal speed, and the optical lens is moving back and fort or up and down. and you hearing like the cd is skipping.. then the problem could be is the optical lens... just replace w/ the exact value for continued protection.. ty
Jun 17, 2011 | Televison & Video
My Hotpoint Aquarius WF440 fills up fine but will not move on to rinse and spin. Engineer been out and says its the heating element. He has asked me to wash on no heat until part arrives. Since then every...
I am fairly confident that the problem is entirely due to the fact that the heater is not working.
You are going to have to wait until the new heater is fitted beore being able to tell if there is another fault.
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Not spinning at all
your washer needs a new speed control board located in the bottom right corner of the machine it controls everything to do with the motor
Mar 31, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Coss
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
