L have the Extreme Mac Soma 360 Wireless speaker. The Speaker no longer accept the charge from the DC power supply. what can I do about this? l have gone to the retailer where I purchased the unit and they are no longer selling the XtremeMac Soma 360. So I as the Consumer am at a loss. I tried calling 866-329-9800 but all I got was an automated response telling me to write my problem and wait for a reply. So please Tell me what my options are. Thanks sincerely , Nicholas.
    Sergeant:
  • 238 Answers
Did you try the xtrememac.com website? It looks pretty poor, but there is a contact link that has a form to contact customer service. The problem is either in the charging circuit or the battery. I don't know how you charge it, so I can't offer much other than the connectors are usually the culprit. The other possibility that comes to mind is the battery. If it's the battery, you'll need to contact them. Batteries only recharge so many times.
Posted on Dec 09, 2014
SOURCE: speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Posted on Apr 04, 2008
SOURCE: HK206 speaker power supply
this is power adapter specs for HK206 found elsewhere
Made by: HON-KWANG
Plug in class 2 transformer
Model No: D12-10-1000
P/N: 66-000-118-01
INPUT: 120V 60Hz 25W
OUTPUT: 12VDC 1000mA
The polarity is negative (-) on the outside and positive (+) on the inside.
I will try RadioShack for this...
Posted on Oct 21, 2008
  • 10 Answers
SOURCE: I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Posted on Jul 18, 2009
SOURCE: I have a set of Platinum JBL Computer speakers
You'll definitely need a power cord for those speakers to work.
Most AC converters should work, even if they aren't at 1.0A
Posted on Oct 26, 2009
SOURCE: Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
I had a problem with flashing red on speaker. Yes, i repair it! it is very simple - you must only change 2 condensers 100uF 10v in speaker. It WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Dec 23, 2009
Want to purchase a 2 nd soma speaker but will it bluetooth connect separate from 1st speaker .want to use speakers in separate rooms playing off one blue tooth feed
No, you will only be able to connect 1 device to 1 bluetooth speaker, but you could connect the device to 1 speaker using the line in jack and then connect to the other speaker using the bluetooth!
Dec 28, 2014 | Cell Phones
I cannot get any sound when plugging in my iphone
Is your stereo speaker turned on ? As far as I know, it does not come with an AC adapter because it takes its juice from whatever Apple device is plugged in. Maybe your phone does not have enough of a charge to power both the speaker and the phone. You could also try to turn up the volume on the speaker and/or the phone.
Dec 11, 2014 | Imation XtremeMac Soma Travel Stereo...
My speaker a soma bt extreme Mac I charge it but it won't turn on and my dad is trying to fix it but he disentangle no hot to open it
If you still have this problem, I recommend you contact their support by leaving a message at http://xtrememac.com/prestashop/12-audio
Oct 09, 2014 | Computers & Internet
Hey I have an hdmx jam xt extreme wireless Bluetooth speaker & after a few seconds after I have paired with mine or a friends phone the music will stop playing, this sometimes doesn't happen if the volume...
To me it looks as if the battery is not charged ok. I'm not sure if you can monitor the battery voltage, but if you could, and you saw the voltage drop bellow a certain voltage and the speaker stopped there, and you could repeat this that would be the case. But perhaps you just charge the battery and discharge it a few times, before you panic. Some batteries only start working with full power after a few charges.
Jun 23, 2014 | Radio Communications
My soma bt speaker will no longer pair
On the iphone in bluetooth menu delete all soma speakers.
on the soma put it into bluetooth discovery mode
on the iphone wait till soma speaker shows up
select the soma speaker NOT the arrow on the right side
wait till the iphone reads 'connected'
if you are asked for a passcode use 0000
Mar 19, 2014 | Imation Xtrememac Soma Bluetooth Portable...
Hi my I phone is not charging while it is on and when switch off it start charging???
Hi -
It is not uncommon for some devices to be unable to accept a charge while in use - especially if not using the supplied charger. This is because the amount of power required to USE the device (your iPhone in this case) exceeds the amount of power provided by the charger.
If trying to make a call, you may be able to coax your iPhone to accept a charge if you shut down un-needed services such as wifi, GPS and BlueTooth radios along with turning the brightness of the display down, etc. This greatly reduces the power requirements of the phone; and if the charger is powerful enough, it will begin to slowly charge your phone. The charge rate will be significantly lower - requiring a longer time on the charger - whenever the phone is being used AND charged. Once the phone is no longer being used, the charge rate will immediately increase, since AC power no longer has to be divided between charging the battery and operating the phone lights, radio, etc. This shortens the amount of time needed to recharge, significantly.
Whenever possible, use the the supplied charger - or one with the SAME voltage, polarity, and voltage type (AC or DC). The amount of current or wattage should be the same or greater than the original. Most phones use USB connectors and are 5 Volts DC. USB standards call for between 1/2 and 1 Amp current. Since watts is equal to volts x amps, this example would represent a 2.5 (if 1/2 amp) to 5 (if 1 amp) watt charger. If you could find a higher wattage charger while still maintaining the DC voltage requirements, you would be able to use and charge the phone at the same time.
I hope this answers your charger question & good luck!
Sep 04, 2012 | Cell Phones
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Panasonic SC-PT467 Wireless speakers Clicking
I had this exact problem. The clicking is something to do with interference from the power supply cable. It seems that facing the wireless unit in the most obvious way ensures that the power cable and the right speaker cables cross. All I did was turn the unit around so that the wires no longer crossed and magically the clicking sound disappeared forever!!!
Good luck !!
May 28, 2008 | Audio Players & Recorders
Yamaha dsp-/e300 wont switch on
check your speaker wire and speaker for short circuit.
Jan 17, 2008 | Yamaha DSPE390 Amplifier
159 people viewed this question
 Grubhead
Grubhead
