I have a Mitsubishi model # ws-65815 was working fine until it was taken apart so it can go down stairs, put back the same way very carefully, no boards were chipped or broken and all the wires are in the right spot but now I'm getting a green flashing light for 5 to 10 seconds then it goes out I push the power on and get a greenish/yellowish picture with red and green lines going a cross the screen the powers off after 3 or 5 seconds. Had any one had this problem or can some give me some repair tips? Oh this is a 65" diamond edition. Thanks to anyone who can help. Greg
  • 1694 Answers
SOURCE: Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Posted on Nov 05, 2007
daniel719
  • 240 Answers
SOURCE: MITSUBISHI BLINKING GREEN LIGHT
replace the dmv pcb, replacing just the cap is a temp fix, that is if it works location number is c9624
Posted on Jan 12, 2009
  • 7 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
Sparko1
  • 167 Answers
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Posted on Aug 03, 2009
Slinteriors
  • 8617 Answers
SOURCE: my Mitsubishi diamond series 65
Try replaceing the DM capacitors that often cures that symptom. You can get the V26 DM repair kit from www.tvrepairworld.com the kit also contains the CD with detailed instructions.
Posted on Jan 08, 2010
Tip
Mitsubishi Convergence IC Part Number List
<b>As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.</b><br /> <br /> <b>Mitsubishi Convergence IC Part # List (complete)</b><br /><br /><br />Ref # / Part # / Part Name & Description <br /><br />CHASSIS: VZ7 <br />MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705 <br />IC8C01 267P141030 HIC-<b> STK392-110 </b><br />IC8C02 267P141030 HIC-<b> STK392-110 </b><br /><br />CHASSIS: VZ8 <br />MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VZ9 <br />MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709 <br />IC8C00 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: VZ6-V15 <br />MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br />MODELS: VS-50800 / VS-50803 / VS-60803 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br /><br />CHASSIS: V16 <br />MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905 <br />IC8D01 267P120010 HIC - <b>STK392-040 </b><br />IC8D02 267P120010 HIC - <b>STK392-040 </b><br /><br />CHASSIS: V17 <br />MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br />MODELS: WS-55908 / WS-65908 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V18 <br />MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V19 <br />MODELS: WS?55859 / WS?55909 / WS?65869 / WS-65909 / WS-73909 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: V20B <br />MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VK20 <br />MODELS: WT-42311 / WT-A42 <br />IC8C01 267P141030 HIC -<b> STK392-110 </b><br />IC8C02 267P141030 HIC -<b> STK392-110 </b><br /><br />CHASSIS: V20 <br />MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: V21 <br />MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: K20 <br />MODEL: WT-42313 / WT-42315 / WT-42413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V22 <br />MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V23 <br />MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 / <br />WS-65813 / WS-73513 / WS-73713 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V24 <br />MODELS: WS-48315 / WS-55315 / WS-65315 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V25 <br />MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250</b>
on Jun 10, 2011 | Televison & Video
Tip
CHASSIS: VZ7
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
CHASSIS: V16
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
CHASSIS: V18
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
CHASSIS: VK20
CHASSIS: V20
CHASSIS: V21
CHASSIS: K20
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
CHASSIS: V23
CHASSIS: V24
CHASSIS: V25
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
How do I take the ws-65413 cabinet apart
IF it can you will see on each side of the cabinet two plastic caps (fairly flat) If they are there they pop out and under each of the four caps a L bolt, rotate it to left and top half of set can be removed from bottom, IF NO CAPS ON BOTH SIDES, IT DOES NOT HAVE THAT FEATURE.
Nov 16, 2011 | Mitsubishi WS-65413 65" Rear Projection...
I HAVE A MITSUBISHI WS65815 HOW DO YOU PROGRAM THE DVD TO WORK WITH THE TV?
You should not have to "program" it. If DVD is HD connect it to the DTV input on the back of the set--if not HD DVD unit connect it to one of the other COMPONENT inputs the set has---
Component will have RED, GREEN AND BLUE INPUTS, for picture plus a red and white for audio---Component requires 5 connections.
Once you have the wires plugged in so they are the same at both the set and the player--you use your input button to go to that input.
The set you have should allow you to put labels on each input which is helpful.
If this information told you something you did not know, rate it as very helpful as I do this here for free.
SD TECH
Aug 17, 2010 | Mitsubishi WS-65815 65" Rear Projection...
Clean/Tweak Rear-Projection MIT WS-65815
There are really only two things that need to be done for service on this set.
FIRST: with the set unplugged remove the back cover and wipe the three large black lens----a paper towel with glass cleaner sprayed on it works fine.
SECOND: WITH the original remote go into the customer menu and select convergence--select the advanced menu and use the remote to adjust--there will be instructions on screen to tell you what to do.
Some people pay 50 or more for a house call when for the most part it is a do it yourself thing.
Let me know if you have questions--I do this kind of work in my area----15 job.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 18, 2009 | Mitsubishi WS-65815 65" Rear Projection...
The television remote controll is broke.
You can get Original Remote for WS-65815 from Mitsubishi Parts.
Nov 24, 2008 | Televison & Video
Protective screen
remove the bottom it should snap off and then see if this model has screws to hold the frame up otherwise it just pop off
Feb 08, 2008 | Mitsubishi WS-65815 65" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
