Question about Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V Receiver
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Not sure if my kids did something, but unit does now power on. Power light changes when plugged in from red (dot) to green for a few seconds then clicks off. No other lights come on. I opened the case to find the fuse next to incoming power is blown 8A 125V. I replaced the fuse to find it immediately blows the new fuse. Nothing odd with incoming power 110v (standard) and unit does not have a incoming power switch to alternate.
    Master:
  • 373 Answers
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Posted on Dec 08, 2014
Testimonial: "Without removing any boards to inspect closer, I don't see any capacitors bulging. I will pull boards and look closer later tonight. I unplugged the transformer from all outbound connections and powered the unit ON... No blown fuse this time... Power cord goes into a small sister board (with fuse) and then to the transformer."
  • SidCharming Dec 13, 2014
    There are no bulging tops. I've looked into a thermal fuse inside the power transformer. Looking at how to gain access to the fuse (found a YouTube video).
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
My Sony STR-DG920 shuts off then comes back on by itself every 4-5 minutes. It very quickly loses power then comes back online. Any ideas what might be the problem?
The problem is the Power Switch. The switch on the STRDGF920 is very problematic. When the receiver is on very lightly move around the power switch with your finger. do not use enough pressure to turn the unit off. Just very lightly slide your finger over the switch and you will see your problem happen. I have two STRDG920 units with the same problem. One is so sensitive I can blow on the switch and it will power cycle off and on. I have called Sony and they said they do not offer a replacement part power switch. I will have to figure something out.
Aug 08, 2011 | Sony STR-DG920 7.1 Channels Receiver
Working on for friend. Unit does not power up, no fuses blown
The most obvious place to check is anything to do with the power supply, such as the transformer. A fuse will only blow if an overload occurs, caused by something acting like it was just a piece of wire. However if something acts like a broken wire, everything justs stops dead and the fuse doesn't blow!
Jun 14, 2010 | Sony STR-DE698 Receiver
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V Receiver Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
