Question about Sewing Machines
Hi, I am having trouble with loopingg under the fabric. Mi have cleaned out the bobbin area and rethreaded. Any other suggestions?
Cleaning out bobbin area and retreading
    Master:
  • 373 Answers
Increase the tension on the upper thread.
Posted on Dec 08, 2014
Thread bunching on the bottom of My Excel 23X suggestions how to adjust
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 06, 2014 | Sewing Machines
Help trouble-shoot jammed machine
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Aug 20, 2013 | Baby Lock Ellure
Somethings wrong with the bobbin, it knots up on the back of material
try these suggestions
Apr 15, 2013 | Singer 3116 Simple
-what causes bird nest with the Janome Horizon 7700 sewing machine?
Apr 05, 2013 | Sewing Machines
Why is my thread nesting on my Babylock BMP8?
Jan 14, 2013 | Sewing Machines
I have error code E6 on my 7258 singer model . What is the problem?The thread is tangling up at the bobbin area.
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine top and bobbin
turn the bobbin the opposite direction
if the suggestions don't help then the machine needs to be serviced
Jan 03, 2013 | Sewing Machines
My machine keeps clogging at the beginning of my sewing
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
Upper thread gets jammed in bobbin area
Dec 12, 2012 | Brother Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
