Question about Toshiba 50A61 50" Rear Projection Television
I have a toshiba 50a61 projection tv, it shows the menu and comes on but does not show a picture or sound.
I have taken the front and back covers off to find if there are bulbs but did not know what I was looking for.
  • kathy taylor
    kathy taylor Dec 08, 2014
    The power light on front is red
    Master:
  • Toshiba Master
  • 688 Answers
I highly recommend you call a technician before you hurt yourself or cause more damage to the TV
Posted on Jan 03, 2015
snakehead
  • 1074 Answers
SOURCE: Toshiba 50A61..power comes on but no picture or sound
my friend your tv got hit before you did the disconnections storm hit sets are a piece of work to fix, it is left with the circuit board burned.my advise is to buy a new tv.good luck
Posted on Jun 23, 2007
  • 3 Answers
SOURCE: Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Posted on Apr 09, 2008
SOURCE: Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
Posted on May 28, 2008
  • 298 Answers
SOURCE: Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Posted on Apr 10, 2009
  • 8 Answers
SOURCE: toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Posted on Jun 26, 2009
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Toshiba 50A61 have sound but no picture - all fuses check okay
Not too many--if sound is developed from the set and not a surround system the set will blank the 3 picture tubes for a few reasons:
Voltages missing at the tubes (high voltage or screen voltages etc)
There is a loss of vertical sweep or horizontal sweep--set will do here this to prevent an INSTANT burn mark on all 3 tubes.
One thing you can try to look for is to see if the filament in each tube is lit---rather dim as 6.3 volt one---if lit the above reasons are your problem.
Without a meter, a schematic etc not much more you can check.
You should hear a faint whoosh sound when you power the set on--the high voltage coming up.
Jun 07, 2012 | Toshiba 50A61 50" Rear Projection...
I have a toshiba 50a61 tv sound no picture
Hi ogmrwizzard,
This is an indication of faulty lamp.
First check the lamp connectors, pull-out, inspect the connectors and then re-insert and ensure its connection from the ballast board. If the symptoms still persist, you must replaced the lamp to back the picture again.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Toshiba 50A61 50" Rear Projection...
Make sure correctly hooked up in back of TV. Then in menu go to audio and be shure that speakers are set to ON. Most TV's you can turn the speakers on and off in the audio menu. If they are still off you might have bad speakers and need to replace them.
Mar 12, 2011 | Toshiba 50A61 50" Rear Projection...
Double vision
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Toshiba 50A61 50" Rear Projection...
There are fuses in this unit, one could be blown there are also capacitors and a regulator that could be at fault I would suggest U find a repair man in your area if possible to go thru this unit find the fault and repair. It would cost less than to repair than buying a new one.
Jun 16, 2007 | Toshiba 50A61 50" Rear Projection...
Color problem with Toshiba
Sounds like a problem with convergence, poss just requires new STK 392-110 ICs , may need a couple of resistors that go due to faulty ICs
Nov 02, 2006 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
