Question about New Home Sewing Machines
I recently had my New Home 7500 serviced. It now has a rattle in the bobbin area as it sews. Sewing is fine unless I speed up then it might thread jam.
Nothing, it sews but was not rattling before I had it serviced.
  • New Home Master
  • 1,860 Answers
Contact the one who serviced it and tell them that the machine is making rattling noise which it didn't do before and see what they say
Posted on Dec 08, 2014
Bobbin thread will not catch. Was sewing fine. What do I do now?
Try a brand new needle--old damaged/bent needle will frequently fail to connect with bobbin thread.
If that does not resolve the issue, most likely the machine has been knocked out of time--most often occurs when the needle hits a pin or is deflected by thick fabric so it hits the needleplate or something in the bobbin area. You can search the internet for sewing machine timing or take it for service.
Jan 02, 2017 | Sewing Machines
Machine isn't sewing right. Underside thread is very loopy. Was sewing fine but thread jammed in bobbin area.
Remove all remnants of the thread from the bobbin area.
First thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the lot by thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. Also try new needle.
Oct 27, 2015 | Sewing Machines
Why has it stopped working?
Most of the time if the bobbin won't engage is you are not making a connection as its has a certain way it goes on. Most New Homes are proprietary on how the different parts engage. If you look and not think too hard take your time, you will discover the proper way to get the bobbin to engage.
Jul 04, 2015 | Janome New Home Portable Mechanical Sewing...
Why is the bobbin thread looping and catching on my sewing machine? The stitches are uneven, too.
Hi Sylvia,
Your problem is an un-matched tension of the threads. You mentioned doing an adjustment recently. That is the problem area.
If your bobbin thread develops loops on the top side of the fabric, you need to tighten the bobbin tension.
There is no easy method for this and you will have to do it slowly -
tighten, test, re-tighten, test.... until you get a near perfect stitch.
I haven't come across a portable device specifically designed to set thread tensions.
Oct 08, 2014 | Dual Sew 3400 Mechanical Sewing Machine
Intermittent sewing problems
You have two problems:
1) Sometime it sews fine, but other times it will sew like there is no tension on the thread and create a "birdsnest" in the bobbin compartment.
Cause : Threading the upper thread
- clean upper thread tensions discs
- do not forget "• raise the needle and presser foot" (see manual page 18)
2) Sometimes it just randomly changes ...
Please open new ticket. Give tu us more info. It seems like Short circuit on S-print, but your description is chaotic (not usable)
Apr 19, 2017 | Bernina Activa 130
New Home 7500 sewing machine top thread keeps breaking?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jan 30, 2013 | Sewing Machines
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
Rattle in the bobbin area.
make sure the bobbin is not warped or damaged
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
