I have a Mitsubishi 60 inch TV new bulb replaced it won't light up what else could be wrong with it thank you
    Master:
  • 373 Answers
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Posted on Dec 08, 2014
SOURCE: Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
Posted on Nov 20, 2007
mistersony
  • 320 Answers
SOURCE: Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Posted on Nov 08, 2008
racer7x
  • 42 Answers
SOURCE: I have the sony 60 inch projection tv. The bulb light is flashing
It depends on the model number .
a lamp is relatively inexpensive and is a breeze to install
I would Google the model number for the correct bulb and you can get a prety good deal
If not ask me for the number and I can get it for you
I just need the model number
Posted on Feb 10, 2009
SOURCE: Mitsubishi VS-60603 60 inch Projection TV
i have a mitsu vs-60603 that when it is turned on all i get is the half screen with red green and blue no picture of any kind what do i need to fix this problem is it posable to switch over to the pip moduale and just use that as my main screen board?
Posted on May 11, 2009
SOURCE: My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Posted on May 19, 2010
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
My picture went very low where you can barly see it
By low, do you mean dark that you can hardly see a pic. If so then the bulb is going out, if its the same kind of tv as mine. Go on Mitsubishi site, and order new bulb, they are pretty easy to replace, instructions on youtube.com too!
Jun 16, 2014 | Mitsubishi WD-60738 60-Inch 3D DLP HDTV
60 inch mitsubishi tv has white spots all over the screen
White spots mean the optical Light Engine is bad.
May 05, 2012 | Mitsubishi Televison & Video
Mitusbishi WD73833 won't power on. Replaced the power board with one from Mitsubishi and it still won't power on. Help!!!
These tvs are known to have sensor issues. EX: door lamp sensor failure. Thermal fuse failure (above bulb)....Check all sensors on the tv and replace with new and you will be up and running again.
Lastly, always double check all connections and check the bulb ballast as well.
Thank you and best of luck!
Jul 11, 2011 | Mitsubishi WD-73833 73" HDTV
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont turn on
sounds like you need a new bulb go to bestbuy with the brand name and model number and ask for a replacment bulb i just replaced mine it was bout 60 bucks
May 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Oct 01, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
