Question about Hardware & Accessories
I have a sauter T37 programmer for heating. When I try to set up a program it has 3 times during the day to set my times but I only want it to start in the evening. When I try to set it won't allow me to set just one time it wants 3 settings during the day and it won't allow example. 8am-8am only allows 8am-8.10am and it's the same for the noon settings etc. I don't need it to come on during the day wasting fuel. Can it be set to only use one time setting of the program
    Master:
  • 373 Answers
Yes, just make the unneeded setting match the one before it so nothing changes at that time.
Posted on Dec 08, 2014
  • Donnie Burke
    Donnie Burke Dec 11, 2014
    This does not work. When I try to set for 12 to switch on it automatically goes to 12.10 off. I can't set times the same.
  • Anonymous Jun 02, 2015
    Did you ever get this solved? I have the same problem, I only want to have the system switch on 1x. Currently I have set it to 3x10min that immediately follow each other. Meaning I can't set it to a shorter total time than 30 min.
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
protek480
  • 1723 Answers
SOURCE: SL5618 Heath Zenith lights on all the time and during the day...
What timer do you have? Maybe I can help you set it up correctly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 10, 2009
SOURCE: lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Posted on Nov 02, 2009
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
SOURCE: Have programmed this timer twice. Set for 7 days
You posted under Woods 59403, which is also sold under different brands and numbers
Open following link to identify timer and download on-line manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
1) I test timers. Some arrive defective.
People write to fixya reporting glitches and problems with this timer.
However, fixya might show complaints because timer is popular. After all, if nobody bought certain brand car, there would be few complaints.
2) This timer resets after power outage, so if you have loose wire, then timer will reset.
3) Timer problems are also associated with interference, noise, or bad wiring. Buy cheap circuit analyzer at home center and test by plugging into outlet.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
4) Try timer on different circuit, for example indoor circuit, and plug in different load.
5) Above information should narrow down if timer is defective, or if wiring or load are causing problem. Return defective timer to Home Depot, Lowes or Target and buy another.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 18, 2011
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 | Heating & Cooling
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
Sauter t27
On/in a laptop? You do know this is the PC Laptop Category?
Nov 04, 2013 | Computers & Internet
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2013 | Hardware & Accessories
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Hardware & Accessories Logo
243 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
