Question about Toys
How do I get an antenna for a G62-xx helicopter ?
Phone 610-779-6390
My sparrow rc helicopter will not turn on and I dont know what to do
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
Jun 23, 2017 | RC Toys
How do i turn on wireless capability on on windows 8 using hp notebook G62
The thirteenth key on the first row of your keyboard has an antenna. If you press this key, the orange light next to it will turn white, indicating that the wireless capability is currently active.
Oct 18, 2014 | HEWLETT-PACKARD HP G62 Notebook
Syma s031
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Why wont my RC helicopter respond to the controller
The Helicopter channel/frequency may need changing to match the channel/frequency on the transmitter.
OR change the transmitter channel/frequency to suit the helicopter.
Feb 06, 2013 | Toys
SO22 Big Chinook helicopter has control problems. It revs up sometimes with no input from the remote.
I also have a S022 and am having the same issues with it powering up. I dont have a solution and I would love to get one. I did try different things with the antenna and it made no difference. i had it loose. I had it wrapped around the body. Now I just have it going around the landing gear. Given that I have had the same problem in all those different ways I am assuming that the antenna is not the issue. If someone finds an answer for the powering up problem than please let us know.
May 17, 2012 | Toys
Can't control my Dura V10 R/C helicopter more than 10 feet away...has new batters...do I need a new remote controller box?
Just bought furs v10, can't control it either. Opened it up and found battery loose, and antenna wire solder joint broken at PCB board inside helicopter. Flew it maybe 3 minutes. Not impressed!
Feb 18, 2012 | Toys
Hey has anyone had problems where the helicopter is flying fine then all the sudden it falls out of the sky. Ive replaced the batteries in the controller and charged the battery and it still does it.
Have you messed with the helicopter wire antenna at all? It's the plain wire that comes wrapped around one of the landing skids and should be left like that. Also, make sure the metal antenna on your remote is fully extended. Normal operating range is 50-100 meters maximum depending on surroundings and interference. Are any of these potentially the issue?
hope this helps,
r
Jan 03, 2011 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Toys Logo
150 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
