Question about SonicWALL SSL-VPN 2000 VPN Gateway - 4 x 10/100Base-TX , 1 x Management (01SSC5952) Firewall
What wires goes to the ports in the back of the sonicwall 205
  • 728 Answers
Hi Heather,
First off don't plug anything into the plug that says Console. Next you have 5 X ports X0- X5 If your just connecting a desktop computer you should plug the ethernet cable from your desktop to the X3 jack, and so one if you are connecting directly to the Router. If you are going to use wireless connection then you don't need to plug anything into the back of the Sonicwall 205, you'll need to log into the router and assign a password so you can log on from your remote device.
That's it.
Good Luck,
Mark
Posted on Dec 13, 2014
Port forwarding sonicwall 4060
Check port setting option policy setting
Feb 06, 2014 | SonicWALL pro 4060 security appliance...
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Firewall as a switch
Yes, there isn't anything wrong in connecting any extra computers on the free ports. Go ahead and plug in your laptop. If it doesn't work, then its the best time to ask here. ;D
Dec 12, 2009 | SonicWALL NETWORK SECURITY APPLIANCE NSA...
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Open Port Sonicwall
1. If the port is to be opened for internal people to access the port outside the network, add a firewall allow policy in Firewall -> Access Rules -> LAN->WAN
2. If the port is to be opened for external people to access the port in the network, add a firewall allow policy in Firewall -> Access Rules -> WAN->LAN
Jul 13, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
Sonicwall Safe mode Problem
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of 192.168.168.200 and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of 192.168.168.168. You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
button.
Apr 07, 2009 | SonicWALL TZ 170 Firewall
How to switch over opt port to wan port in sonicwall
In order to do this, you will need to order the sonicwall OS enhanced. You can do this from your mysonicwall.com account.
After you upgrade the firmware, you will have a network load balancing option. you can then set the primary and secondary connections and use the active/passive failover option that is provided.
Jan 10, 2009 | SonicWALL Content Filter List (01SSC2733)
How to configure Sonicwall TZ 190? I have connected console to the Sonicwall and trying to open it via Console. But no configuration or prompt is coming. Kindly help ASAP.
open control panel and then add printers and other hardware, then up in left hand menu go to system then hardware, device managed and check if your driver is updated. if it says it's working properly then uninstall it and it'll pop back up reinstall then it should work fine.
Dec 03, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
SonicWALL SSL-VPN 2000 VPN Gateway - 4 x 10/100Base-TX , 1 x Management (01SSC5952) Firewall Logo
631 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
