Question about Home
I need a manual for temtex TLC 423 fireplace
I need to replace or repair the damper on my Temtex fireplace model # TLC 423
3 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: can i put harwood floor up to my gas fireplace insert
I don't see any problems for a fire hazard if that is what you are looking at. The reason I would stay away from that is the heat is going to damage your floor by warping or creating dry rot.
Posted on Feb 02, 2016
jonsnell4
  • 22777 Answers
SOURCE: I'm looking for a manual for the Temtex gas fireplace model ADL 36-1 and/or ADL 36-1N
Try here
http://www.manualsonline.com/support/temco-tool/indoor-fireplace/how-to-use-temco-adl-36-2-ventless-fireplace-5593732
I think it is obsolete though.
Posted on Jan 10, 2017
Testimonial: "when I click the link it goes to a gas outdoor grill - not an indoor gas fireplace. I understand that the actual model number ADL 36-1 or ADL 36-1N has been discontinued. However, we are selling the home and have been requested to provide the manual. I've not been able to find anything online."
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Can i put harwood floor up to my gas fireplace insert
Feb 01, 2016 | Heating & Cooling
Installation instructions for a TemTex fireplace installed around the 1970 - 1985 period
surely you jest . try contacting the manufacturer of that item
Jun 07, 2015 | Heating & Cooling
Damper does not open all the time
I believe your concern is with carbon monoxide (CO). The erratic damper operation may indicate that the whole assembly should be replaced.
Nov 30, 2013 | Field Controls 6" Gas Vent Damper Gvd-6pl
I have a Cozymizer gas fire. Does it need an additional vent fitted to the room in which it is installed?
If you have the Cozymizer 1, coal basket gas burner, it's meant to be placed into an existing solid fuel burning fireplace. The damper of the fireplace must be open during operation. If this is the case with yours, no additional venting is required. If this is not the Cozymizer model you have, please provide the correct model number.
Hope this helped and thanks for choosing FixYa.
Sep 15, 2011 | Heating & Cooling
We have a Marco fireplace and the damper does not shut. I push the leaver inwards but nothing catches to keep it closed. We purchased this house and the fireplace was replaced with Gas Logs but still...
when the gas logs were installed the vent damper should have disabled. it sounds like this was done.it is unsafe to close the damper with gas piped into the fire place. sometimes a "u" block will be placed over the damper blade. if the gas has been removed and not piped into the firebox anymore it would be safe to remove this
Jan 27, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I want to know what a lever in a fire place is
The lever at the top of the fireplace operates the "damper". The damper is a door that opens the fireplace to the outside via the chimney.
The damper must remain open whenever a fire is burning in the fireplace to allow smoke to escape out the chimney instead of filling the fireplace and eventually, the room. The damper should be opened prior to starting a fire, otherwise the handle will be too hot to handle. Once the fire has gone completely out, the damper should be closed to prevent heat from being drawn out of the room / home. You can easily check is your damper is open or closed by simply looking up the chimney. If dark, it is closed. If light(er) it is open. Do not operate the damper while looking up - as dirt, soot, rust, etc. can fall when doing so.
The damper also prevents pests from enter the room / home. It is not uncommon for birds, bats squirrels, etc. from creating a home / getting caught in side the chimney.
I hope this helps - good luck!
Nov 12, 2010 | Coleman Heating & Cooling
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Home Logo
35 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
