Question about Dishwashers
Door won't latch - Dishwashers
  • Dishwashers Master
  • 744 Answers
My name is Peter. I am a retired field service appliance technician.
You have a broken door latch. Send me the dishwasher model number, it is on a label on the inside of the door, and I will help you fix it
Posted on Dec 09, 2014
Door won't open from inside '98 silverado
your door rod to your latch must have popped off your inside door latch. take your door pannel off and the door rood will be unhooked
Dec 12, 2012 | 1998 Chevrolet Chevrolet silverado
1995 Voyager Front passenger door latch stuck - door won't close
insert blade of screwdriver behind cam like piece pull up on handle and push up on cam like piece this should reset the latch
Dec 10, 2012 | 1995 Plymouth Voyager
Back door won't close
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Nissan pathfinder rear door won't open
I have had this issue twice on my '98 Pathfinder. The hinge inside the exterior door latch rusts over time and sticks. As suggested in some other answers, the BEST way to get it open is as follows: Pull the latch open and spray WD-40 into the handle openings using the spray tube that came with the WD-40. You may need to repeat this. Note, when I use the word 'latch', I'm talking about the part you pull to open the door, not the lock, which is a separate part inside the door connected to the latch by a metal rod.
There are many ways to then hit the latch to jar the stuck hinge loose. To prevent damage, I folded up an old dish towel, placed it over the latch, and pounded it with medium force with a rubber mallet. It may take just a few hits, or it could take literally hundreds. Initially, the exterior latch will flop loosely. You can see if you're making progress by checking the latch periodically. It will gradually start to break loose and this will be reflected in restored tension in the previously floppy latch. The longer you hit, the tension will eventually be felt through the whole range of motion in the latch. Once full tension is restored, it will open the door.
The first time I did this repair, I simply considered it fixed and stopped working on it. Big mistake, because the locks stuck again in just a couple months and took a lot more work to get open the second time. These latches are cheap and easy to replace (check rockauto.com or other sites - I got my new latches for $12 each).
You must be VERY careful when changing them, otherwise you'll be opening up the door, which isn't necessary if you do it right. To change the latch - remove the two grommets from the door jamb at the latch. Use a 10mm nutdriver to remove the two nuts holding the latch. Care must be taken not to drop the nuts inside the door, but the nuts are angled slightly upward, so gravity is on your side.
Next, CAREFULLY pull the latch out of the door the minimum amount necessary to clear the opening and expose the latch rod that runs from the latch to the lock. IMPORTANT: Before removing the rod from the latch, get a pair of small locking pliers (long hemostat or needle nose vise grips) and attach it to the rod about 1/2" below the latch to hold it in place. This is necessary because once you remove the two nuts holding the latch to the door and the nylon grommet that attaches the rod to the latch, the only thing holding the rod in place is gravity. If you lift the rod more than about 1" while doing this work, it will disengage from the lock inside the door. I learned this the hard way on my first door and actually dropped the rod to the very bottom inside the door. Once the rod is secured with pliers, remove the rod from the nylon retainer clip on the latch and pull the latch free from the door. Installation of the new latch is the opposite procedure.
The second door was a breeze to fix since I didn't have to remove the door panel to retrieve the rod - the whole replacement took less than 10 minutes.
Oct 15, 2012 | 2001 Nissan Pathfinder
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
95 dodge caravan drivers door won't latch
often normal door latches will wear out causing the door latch to not activate the "full latch". The full latch ends up moving further up and into the latch. the solution is to replace the latch or have it rebuilt.
Aug 03, 2012 | 1995 Dodge Grand Caravan
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
FRIGIDAIRE dishwasher door won't latch
Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
Jul 21, 2012 | Frigidaire Dishwashers
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
