Question about Dryers
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
STW-1223C2P, check heating elements, looks like thermal fuse is bad.its dark brown
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Posted on Dec 13, 2014
Testimonial: "Yes, we closed that damper setting,temp like 40 or lower, customer start complaining about heat, we reinspect all units,in some unit's heating coils's end part is dark brown, seems like fuse is attached and it burnt. is any idea can you provide us? thx a lot"
huuum
  • 750 Answers
SOURCE: no heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Posted on Sep 22, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 05, 2009
  • 1122 Answers
SOURCE: blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Posted on Apr 15, 2009
  • 11 Answers
SOURCE: Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Posted on Apr 27, 2009
canbruce75
  • 1776 Answers
SOURCE: my dryer tumbles but throws cold air.
See if there is a high limit thermostat and if there is, check it with an ohm meter. There should be no resistance. If there is resistance, the high limit thermostat is bad and must be replaced.391cb07.jpgThis is a picture of the thermal fuse and high temperature thermostat for your model dryer, to give you an idea of what it looks like. Hope this helped.
Posted on Jul 17, 2009
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
My 7yr old Amana PTAC unit, Model PTH123B50AJ sometimes works and sometimes not. I had a repair tech check it & he told me the control board was bad and they wanted $440 to fix it. I told him no,
EBay often has the control boards for Amana heat pumps, and installing them is fairly straightforward, provided you have some experience with electronics, a soldering iron, etc. Amanapartsonline.com may also be able to sell you the part, which should run between $50 and $150.
Given, however, that the thermostat is also showing problems, as well as what parts are going for these days, I'd seriously consider upgrading to a new unit and selling the old one on Craigslist to offset the cost a bit. If you can find an HVAC technician, someone who's learning HVAC, someone who just wants it for a guestroom where it need not work perfectly or a landlord who can afford to have a secondhand unit fixed and put it in one of their properties for their tenants to buy your fixable old one for a few hundred dollars and a new one only runs about $700, your upgrade will cost less than having the 7-year-old unit repaired, plus you'll be recycling.
Aug 31, 2012 | Amana PTH123B50AJ Heat Pump,12000BTU,...
Fan stopped working
Without knowing the model, I would first check the fan motor for seizing, then if not seized, I would replace the fan capacitor. (Available at most appliance parts stores or
HVAC parts stores). If this is a motel type PTAC unit (through the wall) I would be looking
at the control panel as the third item to check, as these fail often.
The fan capacitor is a small cylinder with usually 2 wires coming to it and at least one of them come from the fan and has its values stamped on the side.
Hope this helps.
Jul 17, 2011 | Heating & Cooling
I have a chance to buy several amana ptac units (ptc074D series) they are rated at 265 vac I only have 220vac. Will they work at 220vac? Is there a conversion kit needed?
The 265/277v units will not work in a 208/230v hotel without a transformer. Basically you do not want to get involved with that. When replacing your PTACs stick with the proper voltage. As far as a conversion kit, if one exists, the cost will put you right back at the cost of a new unit. If your hotel is wired for 208/230v it won't give the unit the power it needs to function properly. When looking for replacement units here's what you need to match (besides getting the proper BTUs):
Voltage
Unit size (make sure they fit in your existing sleeves)
Power cord configuration (the 265/277v will have a different power plug)
Good Luck!
May 14, 2010 | Heating & Cooling
Ptac not heating
the board or the heater need to be replaced
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Dryers Logo
106 people viewed this question
Top Dryers Experts
