Sony KDF-E55A20 55 in. LCD Television
Problem for Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20
By dstar on Nov 11, 2007
hi,
I have the above tv and power light blinks red 6 times.I checked the internet and found that probably problem is in the thermal fuse but what is the part number for that and how can I replace it?
Thanks
Cat lover
Same Problem
Jun 24, 2008
-   I press the power buton the green light flashes as if it about to turn on but then it does not turn on and it flashes red like 4-6 times then stops then starts flashing red again and repeats this until I unplug the TV.-   elietoby
Dec 08, 2007
-   lights up green then go redlight in lamp-   Guest
Dec 06, 2007
-   KDF-E55A20 sony tv
I have this problem and have order thermal fuses from parts store
Sony: THERMAL FUSE--
1-910-023-93-- $5.95
I have opened up the back of the tv to reveal the electrical components. The cooling fan is to the right (when looking from the back) It is a 12 volt unit. Parts store list several fans 1-787-065-11 sony (sirocco--$76.15) or direct replacement 1-0787-460-11 $25.27 they also list another Sirocco fan with a different part number (same price.)
My question is how do you determine if the fan is defective--
I am leaning to the fan as a source of the problem. Not producing the right CFM (air flow) or pulling too much current or both.
Also: in looking from the rear--where is the thermal fuse located.
-   Guest
Nov 21, 2007
-   This just recently occured with my Sony 55" LCD TV.  It's only 2 years old and can't see this TV be broken already.  Any idea what it might be? What's with this thermal fuse and where is it located? -   Guest
Best Solution
posted on Nov 30, 2007
Very Helpful)
electroguy
Rank: Guru  Sony Expert
Rating: 87%, 107 votes
the optical block would have to be removed or loose inorder to get to thermal fuse housing.Also make sure to clean cooling fans carefully to remove crusted dust.If fans are dust crusted ,then your thermal fuse may not last..
Was this helpful?
Yes
No
Solution #2
posted on Jan 15, 2008
Helpful)
kksaito
Rank: Apprentice
Rating: 92%, 4 votes
I want to clean the projector sitting in the back as I see that there is some dust on it. I dont know if that is a good idea or not or if it will even make a difference with the image on the screen. I want to take a pc of cotton and windex to it while I am waiting for my thermal fuse. Anyone with advice?
Was this helpful?
Yes
No
Solution #3
posted on Nov 17, 2007
Not Rated)
Donly82
Rank: Apprentice
Rating: 0%, 0 votes
I ordered my replacement from Partstore.com item number 191002393. cost like $3.
Was this helpful?
Yes
No
Popular Solutions for Sony KDF-E55A20 55 in. LCD
Questions and Unsolved Problems for Sony KDF-E55A20 55 in. LCD
Do you recommend Sony KDF-E55A20 55 in. LCD Television?
Answer
Answer
my tv works fine and then the picture goes black and sound goes out then the picture comes back... (More)
Answer
set shuts itself off then goes back on after a few seconds they goes off again etc.
Answer
sony kdf-e55a20 red light blinks 6 times in a row? just replaced lamp?
Answer
I get the red light flashing 3 times. I change the bulb but it only work for 10 minutes and then... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KDF-E55A20 55 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
