Question about Electrolux EL8505A Bagless Upright Vacuum
My El8505 turns off when I pull it backwards. Whats the cause?
Changed brush bar and belt
  • Robert Hunter
    Robert Hunter Dec 11, 2014
    More detail. In higher nap carpet as I draw the vacuum back the cleaner turns itself off but only on higher nap carpet.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Loose wire
Posted on Dec 12, 2014
Brush bar does not turn when unit is turned on, belt is intact and no noticeable defects.
LOts of these units have a switch for brush or you have to pull back on the handle to start brush.
Hope this helps Mike
May 23, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Where is the reset on electrolux EL8505?
it may be the rocker arm located under the the switch.They are plastic and break,best bet is to take it to a repair shop Not too expensive of a fix
Sep 01, 2014 | Electrolux EL8505A Bagless Upright Vacuum
Why does Beater Bar Fail to turn
Per owner's manual
1. Make sure the brush control is set on carpet mode.
2. The brush will only spin when the handle is reclined.
Others:
The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
EL8505 brush will spin at only certain handle positions. The brush is unhindered and the belt is in position and in good order. The vacuum feels like it is sufficient. When the brush is not spinning the...
Many vacuums have a switch positioned somewhere by the pivot point that is pressed when the catch is released and the handle taken out of the 90 degree storage position. I haven't worked on an EL8505 but I have fixed a couple other brand / model vacuums that were behaving the same way you describe in your problem. In most cases it is either a perfectly good switch that had moved out of position because the framing it is supposed to sit in is broke or worn down or a bad switch that only works when the plunger was in just the right spot.
The link is a parts blowup of your vacuum and I think A-26 is the part you need. It appears to have both the bracket and the switch in one part. Make sure where it mounts doesn't have any damage preventing it from staying in the right place and alignment.
Electrolux EL8505A Parts List and Diagram eReplacementParts com
Mar 23, 2014 | Electrolux EL8505A Bagless Upright Vacuum
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do you replace belt on brush?
Remove the plate on the bottom front of the vacuum by turning the plastic knobs on the plate with a nickel or screwdriver. Then pull out the brush bar and slide the belt over the brush bar and align it with the "cogged" portion of the brush bar.
Slide the belt and brush bar up into the vacuum and over the small cog on the motor. You'll need to pull back the idler pulley which is the smooth metal cylinder next to the cog on the motor. Once everything is lined up push the brush bar into its slots and reinstall the bottom plastic plate onto the vacuum. Everything should be in good working order now!
May 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi,My agitator brush won't run on my hoover S3590, I changed the belt, that didn't work. I don't see a possible cause in my book except replacing the belt. I think there could be a short, the brush will...
Hi Bobbie Take apart the electro floor head if you can and inspect inside - it may well be that there's clogged dust preventing the brush from turning and also check both sides of the actual beater bar as thread and tangled hair can often lead to a brush turning every so often.
Mar 03, 2009 | Hoover S3590 Bagged Canister Vacuum
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Electrolux EL8505A Bagless Upright Vacuum Logo
50 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
