Question about Speed Washing Machines
Why is it that i only have a low and med final spin and not a high speed final spin after replacing the motor and thr shift clutch?
I REPLACED THE MOTOR AND THE CLUTCH, AND NOW ONLY HAVE A LOW AND MED FINAL SPIN. NO HIGH SPEED FINAL SPIN. THE CLOTHS ARE STILL VERY WET AT END OF SPIN CYCLE.
  • 3 more comments
  • Anonymous Dec 09, 2014
    http://www.appliance-repair-it.com/GE-wa...
    sry too many returns anyway you can find the exact error is 6 flashes this means the motor cannot turn so i think you havent properly cleared the error from before follow the clear error text in the above link see if it works
    lol i realise chances are if you fit another controller board this will also clear the error LOL:))) hahahaah
    from what i read an error is detected but not always stopping washes i assume so a machine can limp along till the error gets seen at service time so it could just need reset and bobs yer granny
Somthing to do with motor pick up coil allignment
the coil on the back needs it position set as per the service manual allignment check the clutch is fully engaged
also check brake isnt on a bit
etc
orrrr a contact on the motor connection plug is a bit burned...
Posted on Dec 08, 2014
Testimonial: "Everything is brand new, and I think that your looking at a diffrent GE washer then the one that I own. Model GTWN4250MOWS. It had a high speed final spin with the old moter and shifter clutch installed. Just was very rustey and flashed a led light code of 6. I order a new control board to see if this is the problem."
Fan only runs on high speed
Wild guess the fan was replaced with a one speed motor. Or the selector switch is bad or not connected. Or the relay/s for other speeds are not getting thermostat signal for some reason.
Mar 12, 2015 | Heating & Cooling
The dana two speed motor will not stopo where it is supposed to, keeps going in and out of gear
check the limit sensors as the motor is not registering the end of the movement
Mar 20, 2014 | 1992 Chevrolet Chevrolet Cheyenne
I have an Emerson (4 Speed) direct drive blower for my gas furnace. What is the process (wire color codes) to change speeds on the blower. (I have a red, black and yellow wires taped off in the wire...
There should be a wiring diagram on the motor itself. The colors of the wires vary depending on voltage and model. Generally you have a med/low and med/high setting, I'm not sure what you are getting to with the low/high setting unless you are trying to set up staging. Check the motor for a diagram, if that is not present post back with all of the wire colors coming from the motor and the voltage.
Sep 25, 2011 | Emerson Heating & Cooling
Transfer case grinds truck only runs in 4wheel low nothing in 4wheel high or 2wheel drive
Manual or electronic t case?
Section 07-07: Transfer Case, 4x4 System, Service 1994 Bronco/Econoline/F-Series Workshop Manual
DESCRIPTION AND OPERATION Electronic Shift Operation The transfer case is equipped with a magnetic clutch, similar to an air conditioning compressor clutch, which is located inside the transfer case adjacent to the lockup collar. The clutch is used to spin up the front drive system from zero to vehicle speed in milliseconds. This spin-up allows the shift between 2-high and 4-high to be made at vehicle speeds listed in the vehicle owner's guide. The spin up engages the front lock hubs. When the transfer case rear and front output shafts reach synchronous speed, the spring-loaded lockup collar mechanically engages the mainshaft hub to the chain drive sprocket and the magnetic clutch is then deactivated. Shifts between 4-high and 4-low can only occur with the transmission safety switches closed. The vehicle's speed must also be within specified limits as determined by the transfer case speed sensor (3 mph or under). Electronic Shift Control System
This system consists of a two-switch control system, an electronic control module, an electric shift motor (7G360) with an integral shift position sensor, and a speed sensor. Switch Control System
There are two control switches located on the upper right corner of the instrument panel for fingertip shift control. The two switches are mounted horizontally and are identified as "4x4" and "LOW RANGE". Two indicator bar lamps are located in the instrument cluster.
When either of the two switches on the instrument panel control are depressed, the first thing that happens is that the electronic control module receives input from the transfer case shift position sensor to verify what position the transfer case is in (2H, 4H or 4L). Next, the electronic control module looks at the speed sensor and the park/neutral position switch or clutch pedal position switch (depending on transmission type). If all conditions are correct to allow the desired shift, the electronic control module will tell the electric shift motor to execute the shift. After the shift has been made and the electric shift motor is off, the control module again looks at the shift position sensor to make sure the proper shift has been accomplished. Finally, the dash indicator light and the pushbutton light on the control panel will be illuminated by a signal from the electronic control module indicating the desired function has been completed.
Electronic Control Module
The electronic control module, located on the passenger side, controls the operation of the transfer case in response to inputs to the pushbutton control by the vehicle operator, the speed sensor, shift position sensor and the park/neutral position switch. Speed Sensor
The speed sensor, mounted on the rear of the transfer case , tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur. Shift Position Sensor
The shift position sensor, an integral part of the electric shift motor , tells the electronic control module the shift position of the transfer case . Electric Shift Motor
The electric shift motor , mounted externally at the rear of the transfer case , drives a rotary helical cam which moves the 2W-4W shift fork and 4H-4L reduction shift fork to the selected vehicle drive position.
Nov 12, 2010 | 1994 Ford F250 Supercab
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
4wd does not work
Electronic Shift On the Fly (ESOF) Operation
The ESOF system is an electronic shift 4x4 system that allows the operator to choose between two different 4x4 modes as well as 2-wheel drive. The operator can switch between 2WD and 4WD HIGH mode at speed. To engage or disengage LOW Range, the vehicle speed must be less than 5 kph, the brake depressed, and the transmission must be in NEUTRAL.
The transfer case is equipped with an electromagnetic clutch which is located inside the case. This clutch is used to spin up the front drive-line when shifting from 2WD to 4x4 High mode at speed. When the control switch on the instrument panel is turned, the generic electronic module (GEM) recognizes that a shift has been requested and activates the electromagnetic clutch and the relays which power the transfer case shift motor. When the shift motor reaches the desired position as determined by the contact plate position inputs to the GEM, power to the shift relays and motors will be removed. When the transfer case front and rear output shafts are synchronized, the spring loaded lockup collar mechanically engages the main-shaft hub to the drive sprocket. Finally, the front axle collar is engaged and the electromagnetic clutch is deactivated.
Shift Between 2WD and 4x4 HIGH:
Shifts between 2WD and 4x4 HIGH can be made at speed. Listed below are the inputs and outputs needed by the GEM to execute a change between any of these modes.
Feature Inputs:
*4WD Mode Switch (Various resistances).
*Contact Plate Position Inputs A, B, C, D (grounded when closed, open circuit when open).
Feature Outputs:
*4x4 Shift Motor Relay Outputs
*Transfer Case Clutch Relay (grounded when relay is on, open circuit when relay is off).
*4x2/4x4 Vacuum Solenoid (grounded when activated, open circuit when deactivated).
*Cluster Indicators (ground when activated, open circuit when deactivated).
Shifting Into/Out of 4WD LOW:
When shifting into or out of 4WD LOW, the GEM requires that the vehicle speed be less than 5 kph, the brake is applied, and the transmission is in NEUTRAL.
Feature Inputs:
*VSS Sensor (Sinusoid Signal: 0.7V-20V, 2.2 Hz/mph).
Brake Input (battery voltage when brake is depress, open circuit when not activated).
*Transmission Range Sensor (grounded when transmission is in NEUTRAL, open circuit otherwise).
8Start/Clutch Depressed Input
Feature Outputs:
*Cluster Indicators (grounded when activated, open circuit when deactivated).
4WD Mode Switch
A rotary switch allows the vehicle operator to choose between 2WD, 4WD HIGH, and 4WD LOW modes of 4x4 operation.
GEM Module
The Generic Electronic Module (GEM) controls the operation of the 4x4 system
Vehicle Speed Sensor
The vehicle speed sensor (VSS), mounted in the rear of the transfer case, informs the GEM of the vehicle speed.
Transfer Case Shift Motor Sense Plates
The shift motor sense plate, an integral part of the electric shift motor, informs the GEM to the positions of the transfer case
Located on the left side of the transmission, this sensor informs the GEM when the transmission is in the NEUTRAL position.
The electric shift motor, mounted externally at the rear of the transfer case, drives a rotary cam which moves the mode fork and range fork within the transfer case to select between the 2WD, 4WD HIGH, and 4WD LOW positions.
4x4/4x2 Vacuum Solenoids
These two solenoids are attached to the upper RH side of the engine compartment dash, and alternately route vacuum to the vacuum motor which engages/disengages the center axle disconnect collar in the front axle assembly.
A module containing two relays which under the control of the GEM, shift the transfer case shift motor between the 2WD, 4WD HIGH, and 4WD LOW modes.
An electromechanical relay is used to activate the transfer case clutch within the transfer case.
Good luck and hope this helps,but start with the simple and check the fuses and wire harness. Both white/light blue stripe wires should have 12V in run. The GEM will ground the left side (closest to engine) solenoid to disengage the front axle. It will ground the the right side solenoid (closest to fender) to engage the front axle. If the GEM doesn't see Neutral it will not let the truck come out of 4Lo. If the GEM had water leaking on it it may well be the root of the problem. The shift motor only has power when the GEM sends it a signal to move the shift lever. Once the shift is completed the motor shuts off. There are 2 wires that control the shift motor. A yellow and an orange. The GEM alternates between 12v and Ground to these wires to control which way the motor turns. The GEM uses the transfer case shift relay module to control the power to the motor. There are contact plates inside the shift motor assembly that indicate the position that the shift lever is in. This is what the GEM used to know what the T-case is doing. Any one of these components can fail.
Jan 10, 2010 | 2002 Ford Explorer
Final spin cycle problem
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Jan 20, 2008 | GE WBSE3120B Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
