Question about Black Diamond Equipment Revolt Headlamp O/S
Revolt charge indicator lamp is flashing red while charging
Plugging it in to usb charger
Does samsung 3 have a special charger
You can get a special charger
Samsung Galaxy S3 Chargers Cables
but you don't have to, all you need is a standard Micro-USB cable to plug into the Samsung, the other end can plug into any USB port in your computer or any USB wall charger.
usb ac adapter Google Search
Feb 23, 2017 | Samsung Cell Phones
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
Where is place on charger to plug USB cable?
AnUSB cable can be plugged into a n USB charger. The charger has a USB port that the cable plugs into, it is usually compliant with most USB charging cables. If your charger has a fixed cable, i.e. for a single make, you cannot fit a USB charging cable.
Most computers now also have the charging facility even when the computer is switched off.
Jul 03, 2015 | Cell Phones
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
How do you set up the chargers
You plug the small plug of the USB cable (OTG) into the OTG socket.
You plug the large USB plug into the charger.
Plug the charger into the wall socket.
Jun 16, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
Wont turn on light just flash back and forth on speed setting
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Sep 25, 2010 | Pride Mobility Products New Pride Mobility...
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
Erm....
Hi there, you need to purchase the accessory which has the usb 2.0, DC in and A/V out on it. This is the accessory that allows you to plug your Zen into the TV to play the movies.
May 30, 2008 | Creative Labs ZEN Vision:M Digital Media...
Black Diamond Equipment Revolt Headlamp O/S Logo
560 people viewed this question
Top Black Diamond Equipment Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black Diamond Equipment Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
