Question about LG Stylish DVD Home Theatre System HT306SU
Unable to get fm reception
The original antenna connection exists, but of no help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • LG Master
  • 924 Answers
Make sure you have an FM antenna connected. If that doesn't resolve your issue, you may have a damaged component in the tuner circuit.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Posted on Aug 10, 2015
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
May 22, 2013 | Sony MHC-GX450 CD Shelf System
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    2007 Sonata AM radio has no sound. Hit search at 100% volume and tuner scrolls non stop. FM is fine. Antenna?
    AM is reflective, FM is not. Best reception is always FM because of this reason. Reflective AM bounces off everything - buildings, trucks, houses, power poles, etc and cause 'shadow' RF which confuses the the radio's AM tuner. However, if this condition exists ALL the time (whether you driving or in your garage), then the problem is either in the audio unit itself or in the rear window antenna (or connection to it). Left "C" pillar cover removed, you'll see the physical connections to the window antenna (it's also the rear defroster heating elements).
    Oct 19, 2009 | 2007 Hyundai Sonata Limited Sedan
    FM Reception with Jensen MSR3007
    I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
    May 31, 2009 | Jensen CD400M CD Player
    !994 Park Avenue FM radio reception poor. AM signal OK
    Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
    Apr 06, 2009 | 1994 Buick LeSabre
    FM reception
    Assuming the antenna connection is not broken, an old trick is to get a sizeable piece of aluminum foil and twist the center of it making a big bowtie. Wrap (twist) the center of the bowtie around the top of the antenna and see what happens. Try turning it so it points in different directions to see if any particular direction gets better reception.
    Mar 31, 2009 | Aiwa CSD-TD901 Cassette/CD Boombox
    No am reception and poor fm reception - 2004 Kia Sedona
    If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
    Mar 15, 2009 | 2004 Kia Sedona
    FM RADIO DONT WORK..MODERATE AM
    hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
    Mar 26, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
    LG Stylish DVD Home Theatre System HT306SU Logo
    113 people viewed this question
    Top LG Audio Players & Recorders Experts
    jairo sanchez
    Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
