Question about Duracell Powerpack 300 - Portable Power Supply with Auto Ju
I cant find the power cord or where to plug it in at
Looking for the cord and looking for the place to plug the power cord into
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Duracell Master
  • 1,632 Answers
Behind white label , remove label , insert the power adaptor to proper hole .
Posted on Feb 19, 2015
Looking for power cord for my Sony 5 disc compact disc player model no. cdp-c231
the best place to find your replacement power cord is to hunt for one at your local thrift stores , as many of the modern electronics now use a very similar power cord. You may find that if your local thrift store sells power converters , those black plastic ones with an a/c plug at one and ,sometimes the other side of that converter has a power cord that is plugged into that power converter. And if you are not easily ashamed , look down your own alley for people who throw their old electronics away ,. you may luck out and find just the right one.
Nov 17, 2014 | Audio Players & Recorders
Cant find where to plug in power cords for emachines monitor screen E15T3r model 568
AC Adapter For eMachines E15T3r 568 LCD Monitor Charger Power Supply...
As you can see from the picture the power plug is a small round connector similar to an audio input. Power Connectors
look for a connector like the DC socket in the picture
Mar 25, 2014 | MPC Computers MPC F1760I 17" FLAT PANEL...
Cant find the block heater cord
need more info, what year, make, model, engineering. just because the owners manual says.there is a block heater, that doesn't mean you have one look around, try to find a short power cord that you would plug into a extension cord, also look at the engine block, look.at all your freeze plugs, this is where most block heaters go, if you do not see anything in.any of the freeze plugs, then.you do not have one the other kind of engine heater, would be in the top or bottom radiator hoses, or even.heat core hoses, again.there would be.a.cord.to.plug into. most of the time, they would pull the cord up to the front, by the grill, so you can plug it in
Dec 05, 2013 | Cars & Trucks
My notebook refuses to turn on, i've switch outlets, double check that all connections are curretly connected, I've taken the battery off waited a few then put it back on - but still nothing, it just wont...
There are a few possible causes.
  • Your computer is coming on, but your screen is out and you just cant tell. You should see light come on and hear a few noises from the cd drive and hard drive.
  • Your power supply is bad (the corded thinggy)
  • Your battery is bad and has damaged the cord too.
  • The plug in the back of the computer is damaged (Possibly from a bad battery melting the connector)
  • You computer has lightning/surge damage and is just broken
  • The motherboard has failed completely
First, test the simple things.
  1. Remove your battery and try to start with only the cord.
  2. Check the plug that the power supply plugs into. Is it loose does it wiggle? It may need replaced/repaired
  3. Plug the power cord back in and wiggle do any of the light flicker? This may confirm step 2.
  4. Take your computer to a simple repair shop and see if they have a power supply you can try. REMOVE your battery first. If it works, great! Get the power supply.
  5. If none of these are the problem, leave the computer at the repair place for them to look at. There are a few other problems, but you probably cant check those yourself.
Jan 24, 2010 | Gateway M285-E Notebook
Can't find plug for power cord
On the back left end. Identified as item 4 below: c8d8f7d.jpg
Aug 26, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x1270 printer wont turn on
If you are looking at the back of the printer, just to the right of the USB port is where the power cable goes. ( o o ) <--- Kinda looks like that but vertical, not horizontal as I drew it. Hope this helps.
Jun 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Cant find a replacement fuse for the power cord
the fuse is located in the cigarette lighter plug, at the end you will see a silver cap and then the disk that goes over the top of it, that will turn and then you will have the front open to replace the glass fuse that is in it... to find the fuse size, after the fuse is out look at the silver ends it will have the size stamped on it... it might be a 40 amp fuse. or 20 amp. just look at the silver sides on the fuse you will find that there... hope this helps you out
Jun 03, 2009 | XRS-757 Radar Detector
Jack is loose where charger plugs in
This same thing is happening with my acer laptop. I sent it to the company about 3 months ago, and it happened again. I really need my laptop and cant take a month without it. I advise sending it in to be fixed to your laptop company.
Good luck (:
Jun 29, 2008 | Gateway (1532852) Power Supply
Duracell Powerpack 300 - Portable Power Supply with Auto Ju Logo
61 people viewed this question
Top Duracell Computers & Internet Experts
Rick Moore
Rick Moore
fred capra
fred capra
Bill Boyd
Are you a Duracell Computer and Internet Expert? Answer questions, earn points and help others
