Question about Navico Simrad AP16 Autopilot for Inboard wRam Cyl to 11 cuin
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Tested that it is getting power but will not power up
  • John Madison
    John Madison Jan 18, 2015
    Thanks, Steve...
    You were spot on but, unfortunately, too ($320) late! I had a local marine electronics guy look at it. He took both my display and the course computer to his shop and plugged them into a system he had that was working. My components worked fine. So, it appeared to be a power problem. But it was more insidious than just that. After reinstalling on my boat (with tightened connections), it worked...briefly. It turned out that the ground wire (not the connections) was faulty. Only when the entire wire was replaced did it work. I'm still at the dock and will be here until April 1, so that will be the "acid test" but I turn it on and off frequently and it always lights up and the rudder responds when I "change course".
    Thanks for your response, though.
  • Navico Master
  • 696 Answers
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Posted on Jan 18, 2015
Turn on normally, go to press auto.... nothing
Hi Ty
This sounds to me like a cabling problem. There is enough "horsepower" to turn the unit on, but the increased current required to actually run the thing isn't as robust as it needs to be.
I would start by checking the connections at the panel or battery. Make sure these are absolutely pristine. (i.e. Clean and tight) Pay particular attention to the terminals and/or crimp connectors, whichever are used. It doesn't take much corrosion here to render the autopilot inoperable. Let me know how you make out.
-Steve
Apr 14, 2015 | Navico Simrad AP16 Autopilot for Inboard...
Why does my simrad ap16 say initializing and doesn't do anything else?
The fact that initialization cannot complete the task at hand is an indicator the device is not capable of accepting new instructions, the circuit prevents reestablishing current instructions from making changes to the unit, or you may need to pay for services to unlock various codes.
May 10, 2014 | Simrad AP16 Second Station
My Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
May 27, 2012 | Simrad GPS
Hi I have a1988 chevy k1500 died changed coil dist wire from coil to dist have fuel no spark any ideas thanks
remove dist cap and rotor, under the rotor there is a control module (its about 1/4" tall, 1" wide, and 2-2 1/2" long) remove the module and take it to a parts store and have it tested. If its bad replace it and put dist back together and try starting it again. if thats not it then have coil check. Oh ya before you take anything apart disconect battery.
Apr 17, 2011 | 1988 Chevrolet K1500
Selenoid bypass valve has failed
Contact don@sun-me.net and he can help you.
May 07, 2010 | Simrad Ap1603r Autopilot Ap16 Rc36 Rf300...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
Simrad AP20
I have AP 20 need controler head where i can get it please advice my email is potango@yahoo.com
May 12, 2008 | GPS
Navico Simrad AP16 Autopilot for Inboard wRam Cyl to 11 cuin Logo
193 people viewed this question
Top Navico Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Navico Boating Expert? Answer questions, earn points and help others
