Question about Kenmore Elite 45986 Front Load Washer
All light on machine are on
Unplugging it.
How do you do a complete void to re set the machine.
Turn off the machine, unplug it and leave it off and unplugged for at leats 15 minutes. Try it again. If the machine comes up with flashing lights or an error code, something has failed in the machine.
Feb 03, 2016 | Washing Machines
Haier washing machine lights won't come on
If the machine still works, then it is just the light in the panel assembly that needs replacing (or the whole panel assembly itself). If the machine is also not working, try unplugging it and letting it stay unplugged for a few minutes, as much as 10. Then re-plug the machine and see it the lights come back on.
May 05, 2014 | Haier Dishwashers
Keurig troubleshooting
Keurig reservoir light flashes when it is still at least half-full or more.
Jan 02, 2014 | Coffee Makers & Espresso Machines
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine,All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I have since put the machine away and have stopped trying to use it. Any help that you might be able to give would be greatly appreciated. Thank you Tandie Grant
Oct 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
LG WM2487H*M Drum light stays lit after each load is completed
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
Feb 12, 2009 | LG WM2487HA Washer
Serger won't start
Try unplugging power from outlet and removing from machine also. Let it go without power for a few minutes then try another outlet. Hopefully it has not had a power surge. It is best to keep unplugged when not in use..
Jan 02, 2009 | Yamata FY900 Mechanical Sewing Machine
Flashing message light
Insert a new 9 Volt battery (machine will work without a battery if you want to ignore the blinking light)
Apr 27, 2008 | Conair TAD2018CG Digital Answering Machine
Kenmore Elite 45986 Front Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
