Question about Building Materials
Open jammed door - Building Materials
    New Friend:
  • 7 Answers
Not enough info...What, where, how is it jamming?
Posted on Dec 23, 2014
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
Driver door jammed on vw golf 99
Hold the door( when it's open) and try to lift it. After moving the door up and down, monitor the hinges, this will let you know if the hinges are getting worn.
drivers door gets used the most, maybe it's starting to sag causing binding.
Jan 17, 2014 | Cars & Trucks
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
1998 Plymouth Voyager drivers side sliding rear door will not open. I have removed the inner panel, checked the linkage and everything appears fine. I deduce that the rear latch mechanism is...
is the door latch mechanism moving and moving far enough to release the latch to open the door,you can`t remove the the striker plate from inside a panel as the bolts that hold the plate go in from the open side of the door jam,these do have a problem with the doors coming off the rails which mean that if this is the problem then the weight of the door will hinder the door from opening you may have to hit the door hard at the latch end of the door or even pry the door open at the same end to get the latch to pop open.the latch may even be seized or just jammed closed. good luck
Mar 02, 2011 | 1994 Plymouth Voyager
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Building Materials Logo
866 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
