Question about Vizio VO320E LCD TV
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
The TV is currently connected with coaxial cable to a Direct TV box. We wondered if we could open the back and test the cables in any way. Before we replaced the mainboard, the Vizio logo light came on but would not turn off and screen remained black. At the time of the lightening storm it was off but was connected to Direct TV box with HDMI cables. It was on a surge protector which no longer works and the HDMI output on the old box no longer worked.
  • 23 Answers
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Posted on Dec 09, 2014
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
Beelz
  • 666 Answers
SOURCE: vizio p50hdtv10a. Tv has sound
sounds like you needed to replace your video fuse before anything normally if you have video but no sound its an audio fuse and vica versa if for some reason both were out I would say your in need of a new power supply I would suggest replacing the fuse and if it still does not work contacting a service tech to run a diagnostic to see what exact part or maintenance you need
Robb
Posted on Nov 07, 2010
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
How do I fix my Vizio TV which has no back light or display?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Nov 22, 2016 | Vizio Televison & Video
How do i repair my vizio E7011-A3
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
May 28, 2016 | Vizio Televison & Video
Vizio 55" E55-C2 LED backlight issues. Was working fine until one day half of the screen's backlight stopped working and so half of the TV shows good and the other half is darker. Tcon or LED driver?
http://electro-medical.blogspot.com/
Apr 13, 2016 | Vizio Televison & Video
Screen black, no video have audio. Went black at some point when I was distracted. Have tried unplug/pause/repugnant - no help. On/off did nothing either.Vizio, Mdl- VO320E, LCD. Not listed on your...
You need to perform the flashlight test. Turn off the lights in the room, turn the TV on, take a bright flashlight and shine it on the screen. Do you see the faint image on the screen?? You could have a defective backlight inverter, defective power supply, or a main board issue. You set will require diagnosis to determine.
Jun 04, 2012 | Televison & Video
The audio on my vizio tv isn't working
Replace the main board. That board controls all the symptoms you're having. You can get the Vizo Main Board 3642-0182-0150 thats the board for your model from www.tvcircuitboards.com it has a 6 month warranty
Feb 16, 2012 | Vizio GV42L 42 in. LCD Television
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Vizio remote vo320e does not work
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Dec 21, 2010 | Vizio VO320E LCD TV
My husband tripped and his elbow hit the screen of our vizio tv...there is no outside damage however, when you turn the tv on...it shows exactly where he hit it and there is no picture, just a bunch of...
Everytime I see this condition it turns out to be the screen itself. This cannot be repaired unless you can find a good used screen somewhere.
Dec 11, 2010 | Vizio VO320E LCD TV
Vizio VW42LHDTV10A lcd. Has vertical lines and siren like noise !
I would have told you MAIN board in the first place.
Jul 15, 2009 | Televison & Video
Vizio VO320E LCD TV Logo
150 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
