Question about Saws
I'm looking for a handle for a power devil 9 inch angle grinder.do you know the size in mm thanks
Tried all the power devil sites.
    Sergeant:
  • 213 Answers
Dear Mark,
9in = 228.60mm
Formula:
mm = in/0.039370
Fare. Well
Posted on Dec 13, 2014
My Makita "GA9020 9"" Angle Grinder has started to vibrate really bad.there seems to be play in the spindal.its used for floor sanding.i was thinking maybe bottom bearing,but just guessing any ideas thanks
Vibrations and excessive play could be caused by one of two or both bearings in the gear housing or the spiral bevel gears. Armature bearings can cause vibrations but usually don't show up as play at the spindle. Also, if the vibration is really bad, you could have several fan blades broke off one side of the armature fan throwing off the balance.
Oct 09, 2013 | Makita "GA9020 9"" Angle Grinder- 15 AMP-...
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
I was given an old grinder a while back (and not told it needed a handle, but luckily found one), but don't know how to get the wheel/blade off to put on another. There is a "key" with it,...
there is usually a spindle lock on the gearcase somewhere that you need to depress while turning the spanner wrench. If this fails what I have done to remove a "stubborn" wheel is use a punch UNPLUG TOOL FIRST and hit against one of the holes counterclockwise to loosen the nut.
May 13, 2011 | Black & Decker Black Decker Decker G750 4...
Makita ga9000 9 inch grinder just stoppe working no burn smell or noise could it be bushes or something more
First check to make sure the outlet you plugged into has power. (You may have tripped a
GFI elsewhere). The next possible problem is either buildup on the brushes and
commutator shaft or in the switch assembly itself. (I have this problem on one of my
grinders due to dust in the switch assembly).
Mar 03, 2011 | Makita GA9020 Angle Grinder
I need help to replace my brushes on a makita 9553NB 4 inch angle grinder the old model i used to have had easy access.. coin sized slots on the handle that you simply uncsrew to reveal the brushes. my...
first unplug the tool, next on the backside you will notice a screw, remove it and slide the cover back to expose the backside of the motor. gently move the springs that hold the brushes tight to the side and remove the brushes and replace. Make sure to replace the springs and then slide the cover back into place and replace the screw and that should take care of your problem.
Feb 18, 2011 | Makita 9553NB 4" Angle Grinder
Do you have a basic training course and knowledge assessment for 115mm and 230mm angle grinders
Hi, a good place is youtube, there are videos on most tools and some very good tips.
Oct 01, 2010 | Clarke Power Products 7 in 9 in Angle...
I need to replace the abs sensor on a 1995 Chevy
No way are they 14.5 mm. Try an SAE socket instead of metric. I think you will find that a 9/16 is the correct size.
Oct 05, 2009 | 1995 Chevrolet Cargo
( I'm Spanish..and leave in Spain)..well...I go change the front whell of my VTX 1800C'02...my mechanic..d'ont know the size of original rim...¡ and I..so ¡¡..(please,sorry my...
Here are all the specs for your bike,Please take time to rate this a fixya.
2003 Honda VTX1800 Retro Spoke
Engine Type: 1795 cc, 4 Stroke - Liquid Cooled - V Twin
Engine Bore and Stroke: 101 mm x 112 mm
Compression Ratio: 9:1
Valves SOHC, 3 valves/cylinder
Carburetion: Programmed Fuel Injection (PGM-FI) with automatic choke
Ignition system:Solid-state digital, two spark plugs per cylinder
Claimed Horse power:107 hp (79.8 kW) @ 5000 rpm
Maximum Torque: 163 Nm (120.2 ft. lbs) @ 3000 rpm
Transmission type: 5 speed
Drive:Shaft
Starting: Electronic
Suspension - Front: 45mm inverted fork, 130 mm travel
Suspension - Rear: Dual shocks with five-position spring-preload adjustability, 100 mm travel
Front Fork - Rake & Trail Angles: 32 / 163 mm (6.4 inches)
Tire- Front: 150/80-17
Tire - Rear: 170/80-15
Brakes- Front:dual 296 mm discs with 3-piston calipers
Brakes - Rear: single 316 mm disc with 3-piston calipers
Overall - Length: 2456 mm (96.7 inches)
Overall - Width: 932 mm (36.7 inches)
Overall - Height: 1128 mm (44.4 inches)
Seat Height: 693 mm (27.3 inches)
Wheelbase 1715 mm (67.5 inches)
Ground clearance 130 mm (5.1 inches)
Fuel Capacity: 17 l (4.5 Gal)
Dry Weight (without fluids): 320 kg (705.5 pounds)
May 16, 2009 | 2003 Honda VTX 1800 Retro Spoke
Grinder Types
Bench grinders are perfect for sharpening cutters, bits, blades and hand tools. Any piece that needs smoothing, shaping, or polishing can be done at the bench grinder. Straight grinders or angle grinders are portable, handheld tools with wheels that range from 4 to 9 inches. They are the best grinders for working on pieces that may be too large to fit at a bench.
Aug 27, 2008 | kawasaki 7" or 9" Angle Grinder
Saws Logo
55 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
