TV is good. Pairing didn't solve ??rmctpf2bp1 stopped working,
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Try this:
  1. TV off
  4. Turn on TV
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Adobe Reader
A master reset should solve the problem.
Dec 20, 2007 | Nokia 5500 Sport Cellular Phone
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
