Question about Plumbing
When Faucet is turned on I get a loud noise. If I use the Sprayer the noise goes away.
  • Michael ONeil
    Michael ONeil Dec 08, 2014
    Kitchen faucet that has seperate hot and cold controls. Faucet loops up and then back down toward sink. A good 10 yrs old.
  • Michael ONeil
    Michael ONeil Dec 11, 2014
    Fixed it. I replaced the Faucet and the non -working disposal unit.
    Master:
  • 560 Answers
Sounds like water hammer. Air in the pipes. Lower volume of water out of the sprayer isn't enough to initiate the hammer. Try shutting the water off to the house and draining the pipes.
Open the offending faucet and turn the water back on this should eliminate the air in the pipes.
Posted on Dec 26, 2014
arealplumber
  • 33 Answers
SOURCE: Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
  • 2692 Answers
SOURCE: hot water faucet makes loud noise when first turned on
Fix Ya, then?
Posted on Mar 19, 2009
  • 23 Answers
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Posted on Jul 20, 2009
  • 349 Answers
SOURCE: sprayer weak working
http://www.us.kohler.com/onlinecatalog/pdf/1084452_2.pdf
Go to page 15 it has an exploded view of the faucet.
Posted on May 23, 2010
  • 349 Answers
SOURCE: kitchen sprayer/diverter
http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
Posted on Jun 06, 2010
I recently installed a Pfister Cagney Single control kitchen faucet with side spray. The spray has no pressure. The water from the faucet is great. What could be the problem?
Could be trash got into hose( i.e., teflon tape, brass shavings, etc.). I suggest that you turn off water, disconnect the hose and try flushing water through the hose with no sprayer attached. If water goes through, then you have a stoppage in the sprayer. The face of the sprayer usually unscrews allowing you to check if there is trash in it.
Apr 09, 2015 | Plumbing
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
Mar 03, 2014 | Glacier Bay Kitchen Faucets. Lyndhurst...
Kitchen faucet sprayer I have a Delta classic single kitchen faucet and I have a side sprayer too. When I try to use the side sprayer the water stops at the faucet and barely trickles out the sprayer and...
There could be a clog anywhere between the diverter and the sprayer. Sometimes the line collapses from age and has to be replaced. Look under the sink to check for leaks.
Jan 20, 2014 | Plumbing
When I first turn on the hot water to my shower there is a loud noise, then it goes away. Why is this happening?
It could be lime/ calcium deposits in the shower head. Soak shower head in clr and it should be good to go
Feb 28, 2013 | Delta Faucet Plumbing
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Moen kitchen faucet set wsprayer can't shut sprayer.
Jul 20, 2009 | Plumbing
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
114 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
