I have the 32H3E led television, and it only shows a black and white screen. Trouble says unplug for 60 seconds and it should show color. Still no color.
Trouble shooting says to unplug for 60 seconds and it should show color. Tried a few times to no avail.
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 09, 2014
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
  • 138 Answers
SOURCE: screen goes black
Check and make sure the software is updated on the set.
Posted on Aug 20, 2008
maatmartin7
  • 1216 Answers
SOURCE: my plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Posted on Oct 19, 2009
SOURCE: Hello, My Protron PLTV-26 TV will show a
on/off button /or stanby button have 2 change new one .....
Posted on Jan 04, 2010
  • 7 Answers
SOURCE: My LCD television is showing pink and purple
Normally when this happens the cause of the problem is either the lvds cable or the main board.
Posted on Apr 07, 2010
Why screen has now black horizontal lightings on white images each side?
load the pics.
for example check the Vertical lines on Samsung LED TV
it's not a permanent fix, and if you want to fix it completely then disconnect all the cables to the main board(AV board), clean the contacts then put them back as they were. Secondly, look around all the connectors in that area where you loosened the screws
Mar 23, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
I HOOK UP A RCA BLUE RAY I GET THE SOUNF AND PICTURE BUT IT'S NOT SHOWING IN COLOR
Check in menu to see if the region is set to Pal Europe instead of NTSC.this should restore colour.if it is already set to pal and giving black and white then switch it to NTSC
Dec 07, 2014 | Sceptre X322BV-HDR 32" LED TV 1366x768, 60...
60" LED tv showing black on the right side
try to replaced the back-light LED driver to fix it..In LCD its called inverter board..
Feb 23, 2012 | Sharp Televison & Video
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Color problem
is it a crt tube screen?
Oct 21, 2008 | Zenith Televison & Video
Have a weird problem M50WH74S RCA
i found out tht it could be the (DMD) Digital_Micromirror_Device i dont know if that is you problem or not
Sep 17, 2008 | RCA HD52W56 52" Rear Projection HDTV
Philips 50p8342
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
