Question about Ovens
I have Premier Pro series #P36S338BP. Pilot on but oven won't engage to heat oven
Nothing. Better to ask first on some things. What should I look for.
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
I own a Kenmore Pro Series Gas Range. We just moved in and cannot locate the pilot light location
there is no pilot light.oven and stivetops have been using a electronic spark or ignitor for more than 30 years now so gas isnt wasted by burning a pilot 24/7/365
Jul 18, 2011 | Kenmore Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Oven will not come on or heat
Check out this tip... just because you get a glow from the ignitor, that does not mean that it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 15, 2010 | Stoves Premier 600GRa Gas Single Oven
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Ovens Logo
60 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
