Question about Dryers
Daughter handed me her almost new HOT Professional Ceramic blow dryer (S510123). Making a terrible noise, but I can't get the case open. Help!
Removed 2 screws, still can't open case
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
In addition to the screws, the molded cases are injection molded in a 'male' and 'female' configuration. Sometimes a bit more than slight pressure is required to disengage the snap-lock of the plastic joint.
Posted on Dec 13, 2014
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Posted on Mar 19, 2008
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
garing
  • 998 Answers
SOURCE: crosley dryer motor is making loud rattling noise
tighten fan
Posted on Aug 06, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My dryer stopped spinning and its making a
Sounds like you have a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
The smell your smelling is probably from the heating coil not getting air over it to send to the drum to dry your clothes, this should go away after you replace the belt and get the blower to turn again.
Good luck,
I hope this helps
Posted on Oct 08, 2009
  • 254 Answers
SOURCE: My Maytag dryer model # LDE7314ACE has been making
go to sears.com, click on parts and service upper right corner, click on parts, enter your model number it will list a parts breakdown/schematic this wy u can determine whhich parts are removable and how its put togetherr and also get part numbers and prices, shop around though prices might seem low but they get you on the shipping check any local appliances stores if any are avaialbe in your area....
I persoanlly would check the belt, the rollers, or an idler pulley,, also maybe any glides or seals if your model has any........replace any defective parts you find hope this helps good day let me know whut u find
Posted on Feb 02, 2010
My professional ceramic tools porcelain round brush blow dryer will not work and I cannot reset it. How do I reset it?
There is no reset button on those. There is a thermal breaker in the barrel if the heating coils get to hot. If this sticks open then it wont work but you cannot reset it.
Sep 09, 2015 | Dryers
Compaq cq-45 laptop light near to caps and scroll blinks , No display
In Most cases this happens when using Nvidia graphics.
You need to open your laptop - call a technician for professional Job is you are not able to do so.
After removing the cooler which usually comes with a small fan (covers the main processor), remove the processor and you will see a chip that need a "HOT AIR STATION" this tool blows very high temperature of air on the surface.
well I used my wifes Hand Hair Dryer - also does the magic.
see image on where to blow the hot air.
now after blowing the hot air, mount your laptop again.
but first, let it cool down.
Sep 04, 2013 | Compaq Presario CQ-45 Laptop Universal AC...
My bobbin is rattling around in the case and making a terrible noise. I have cleaned the casing and made sure I've put it back correctly and I'm using the correct bobbin - help!
try a different bobbin
if changing the bobbin doesn't help then the hook and hook race
needs to be checked to see if there is a problem with them
Dec 16, 2012 | Sewing Machines
Elna 2800 making noises when flywheel engaged
if the machine is new & it's already making noises, the I'd suggest taking the machine back & getting another
Mar 26, 2012 | Elna Sewing Machines
My dryer is an old model kenmore, model # 76692600, that has started making a terrible rattle when the dryer is running. How do I get the top off odf the dryer so I can inspect the drum motor?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 05, 2011 | Kenmore Dryers
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Loud Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
