Will not connect to wifi just hangs at authenticating already talked with my ISP everything is fine on my end. no connection problems.
Reset modem, save modems password reboot tablet. talked with isp everything is good on my end all other wifi devices connect but tablet will not.
  • 682 Answers
If it is a dual band router make sure it is still transmitting on 2.4htz as this is what most older tablets work on.then scan your networks , when it finds you network don't join but click far right arrow.what you need to do is forget the network because this will clear all previously stored passwords for that network that are kept on the device.then rescan , this time when you click join you can put in the latest password and it should be fine.
Posted on Dec 10, 2014
sandrew
  • 2961 Answers
SOURCE: Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Posted on Oct 26, 2006
  • 9 Answers
SOURCE: unable to conect to dodo isp
First make sure that you have a valid connection to the router and that you have a valid IP address.
(note: for a wired connection you should have a link light on the numbered port of the router to which your computer is connected. You should have an IP address in the range 192.168.2.x. To check your IP address, click on Start, Run and type in command. Click OK. Now type in ipconfig and hit enter. Your IP address will be listed.)
For the F5D5230-4, F5D6230-3
Open a Web Browser
1. In the address bar type http://192.168.2.1
2. Click on Intial Setup
3. Select PPPOE and click Select
4. Type in your username that was assigned to you by your ISP *
5. Type in your password that was assigned to you by your ISP twice
6. Leave Service Name blank
7. Click on Enter
8. Click on Status in the left hand column
9. It should now show Cable / DSL Connected under the Internet column
For the F5D5231-4, F5D6231-4, F5D7230-4, F5D7231-4, F5D7231-4P, F5D8230-4, F6D3230-4
Open a Web Browser
  2. Click on Connection Type in the left hand column under Internet WAN heading
  3. Enter your password if any and click Submit
  4. Click on PPPOE and then click on Next
  5. Type in your username that was assigned to you by your ISP *
  6. Type in your password that was assigned to you by your ISP twice
  7. Leave Service Name blank
  8. Click on Apply Changes
  9. Click on the Home link at the top of the screen
  10. It should now show Connected as the Internet Status at the top right hand corner of the web page
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Posted on Dec 06, 2008
Tech_Mate
  • 680 Answers
SOURCE: Westell 327W15-06 Modem/router password doesn't work- can we reset?
Look for the reset button on the router it will set it back to factory default
Terry
Posted on Feb 25, 2009
ciscoroute
  • 87 Answers
SOURCE: My dataone WA3002G4 (BSNL) modem is not connecting to internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Posted on Jul 08, 2009
The connection in the router is there but we cannot use it. what we are going to do
Perform a full reset of the router. With the power plugged in, press the reset button for 30 seconds; keep the reset button pressed and pull the power plug out for 30 seconds; keep the reset button pressed and plug the power back in. The unit will reset to the factory settings.
User the software and instructions that came with your router, or download them from the Linksys website, and log onto the router and use the setup program to finish the setup.
Jan 02, 2015 | Linksys Wireless-G WRT54G Router
None of my wifi devices connect to my Huawei E5220 mobile wifi. How do fix this problem? It keeps giving authentication problem
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Aug 11, 2014 | Huawei Computers & Internet
Dell n4010 wont connect to internet
Check ALL cables and reseat, try a Ethernet cable connected directly to the ISP modem. If you can connect with a cable, reboot the Wireless device. If no, contact your ISP to verify a signal, it may be a outside equipment issue. Unplug everything remove batteries when applicable, start at the ISP modem, allow the self test with the modem and wireless device. Reboot the laptop, Is your SSID in the Available Wireless Networks?
Apr 07, 2013 | Dell Inspiron Computers & Internet
My att 2wire modem resets itself when i connect to the network. All the lights are fine and everything is normal until i connect to the network through wifi or ethernet. Once i do that, the system lights...
Welcome to FixYa! You maybe experiencing problem with the modem itself. The only way you can fix the problem is by resetting the modem. Once done, and the modem is is still acting the same way, you will need to replaced the modem. Please follow the steps below to reset the modem.
Note: Once you reset the modem, all the username and password that you or your ISP configured will automatically be deleted and goes back to default settings.
1. While the modem is on, press and hold the reset button at the back of the modem for at least 30 seconds. The reset button is like a red hole near the DC port. you can try to use a pen or a pin to press the reset button.
2. You can verify if the modem is already resetting if all the light are turning yellow or amber.
3. After 30 seconds, power down or turn off the modem for 30 seconds again then turn it back on.
4. If your ISP configure the modem with a username and password, you will need to contact them for reconfiguration.
5. Once the configuration is already done, monitor the modem if it will do the same thing.
I hope this information will help. Thank you for using FixYa.
Mar 15, 2011 | Computers & Internet
Weird disconnection problem
How long have you had your modem? If your modem is old it could be as simple as getting a new one. Or it can be the isp faught. I would talk to your neighbors if you know anybody that has the same isp to see if they have trouble or not.
Oct 02, 2009 | Computers & Internet
Won't connect to internet, says local access only, internet provider says everything is alright on their end, need to talk to acer. Been working fine and just quit.
Disconnect your modem/router for 5min then try agian.
If this don't fix it, try locating other wifi (your using wifi right?) hotspots. If you can connect then its your settings on your notebook (since you said its not your ISP.
Delete your internet connection and manually redo it. It could just be some internet settings that were changed.
Need more info on what interenet type your using.
Jun 08, 2009 | Acer Aspire 4315 Notebook
Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
Oct 12, 2008 | D-Link DSL 302G (DSL-302G) Modem
2wire sbc wireless modem connection
      Dylan,      I don't know who your ISP provider is, but I am using BT and had to change to a Belkin modem so that I could connect Archos 605 wifi and Palmone.  Had the same problems as you have, which have disappeared on installation of Belkin modem,
                             Samcalm
Jan 05, 2008 | Archos 605 Digital Media Player
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
