Question about Car Audio & Video
I have 2005 Cadillac deville and the CD button when pushed says no CD loaded...the cartridge is full and when the eject button is pushed it does nothing...and sounds like there is no power to the CD changer....can u tell me what I need to do?
    New Friend:
  • 35 Answers
Start with a test light or multimeter on the wiring harness, to see if there's power to the changer
Posted on Dec 30, 2014
SOURCE: cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Posted on Jan 03, 2007
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Posted on Mar 23, 2009
SOURCE: I have a shaker 500 car stereo with a 6 cd disk
It is a mechanical problem. I had the same issue (still do) in mine. There is a set of small gears on the left side that tend to get stripped (as in the case of mine) then the whole CD tray system fails and literaly locks up. Only thing you can do is replace the head unit, or find where you can get the CD tray. So far I havn't had luck in locating the CD tray.
Posted on Dec 03, 2009
franktilt
  • 403 Answers
SOURCE: '02 Ford Explorer 6 CD
Are you using Burned cd's
Posted on Jan 27, 2011
What causes the throttle body to chatter when key is activated?
Search Results
    Cadillac DeVille DTS - YouTube
    ? 2:09
    https://www.youtube.com/watch?v=dXLzsEm1-0Y
    Oct 20, 2010 - Uploaded by 1969Bossman429
    We dropped our 2000 Cadillac DeVille DTS off at the local Cadillac ... He got into the vehicle, turned the key and the vehicle was still revving at full throttle. ... He raised the hood, reached in to the throttle body area and cycled ...Missing: 1994 ‎chatter ‎activated
    1994 Cadillac Sedan DeVille [Archive] - Cadillac forums : Cadillac ...
    www.cadillacforums.com > ... > Cadillac Reviews
    Jan 17, 2005 - For my Review I will write about the 1994 Sedan Deville. ... A stifferbody this year made the Deville much quieter over the outgoing 1993 DeVille. ... First is a key when your looking at just about any Cadillac, push "off" and "warmer", this ...Have a helper hold the throttle plates wide open with the engine off.
    Cadillac DeVille Questions - Cadillac Deville 2001 won't ...
    www.cargurus.com > Questions > Cadillac > DeVille
    CarGurusJan 21, 2014 - Cadillac Deville 2001 won't start, engine won't turn over - My cadillac won't start. When i turn the key the engine wont turn over and when i do turn the. ... bad replace was told alt was intermenting so that's wat caused issue now car .... intake plenum (the tube between the Mass Air Flow and the throttle body).Missing: 1994 ‎chatter ‎activated
Jan 03, 2016 | 1994 Cadillac DeVille
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 22, 2012 | 2005 Jaguar X-Type
Jammed cd in cd player with is a inbulit 6 stacker cd player that came standard with my car
if you can not eject cartridge
PRESS AND HOLD EJECT BUTTON
Insert credit card or similar under cartridge push fully in and move under cartridge,this will locate micro switch and eject
Then you can check discs
Jun 06, 2010 | 2003 Mazda Mazda6
Stereo and cd player are seperate units
I take it you have a cd stacker
PRESS AND HOLD eject button,insert credit card under cartridge
Push card firmly in,move left -right,this will locate micro switch.
Cartridge should pop out so you can check discs
Dec 20, 2009 | 2002 Cadillac Escalade
Battery died - replaced the battery yesterday but now the 6 disc changer will not operate - radio and clock work fine but it's like it does not even know there is a cd player in the car. every 30 seconds...
I take it the cartridge will not eject
If so press and HOLD eject button insert credit card or similar under cartridge push firmly in and move left/right
This locates micro release switch
Make sure nobody has inserted discs upside down
Nov 20, 2009 | 2005 Dodge Durango
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
CD PLAYER IN 2005 CHEVY EQUINOX WON'T WORK AFTER BATTERY DIED
on most,,, flip down face plate and there should be a tiny hole you can push a safety pin in to eject. or a tiny button. good luck
Dec 06, 2008 | 2005 Chevrolet Equinox
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Nov 14, 2008 | 2005 Ford Expedition
6 disk problem
i own a 2005 mazda 3 with 6 CD and you should be able to push the load button the player will scroll through what is in the player and then start flashing a # where it is going to put the new CD, this is when you can load,But if your player is already full it will not allow you to add anymore without ejecting one
Aug 02, 2008 | 2005 Mazda 3
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
