Question about Kitchen Ranges
Why is fan speed no.(1) still blinking on my range-hood (bertazzoni KG36CONX)
SOURCE: Smeg P580 range hood
Hold the fan button down for a couple of seconds and it will turn off.
Posted on May 07, 2008
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
  • 80 Answers
SOURCE: ISL93.IKSS range hood display flashes "A" and little/no suction
Check to see if your filter is plugged that will slow the air flow.
Posted on Oct 02, 2009
localwonder
  • 6784 Answers
SOURCE: noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Posted on Dec 11, 2009
derrickbohan
  • 90 Answers
SOURCE: 3 speed fan to range master hood stays on one
sounds like a bad fan motor or control
Posted on Dec 16, 2010
How to remove oven door
Bertazzoni X366GGVX Stainless Steel Gas Range Remove ...
www.fixya.com > ... > Bertazzoni X366GGVX Stainless Steel Gas Range
Bertazzoni X366GGVX Stainless Steel Gas Range"remove oven door" Questions. Question about Frigidaire Kitchen Ranges. 1 Answer ..
Aug 11, 2015 | Bertazzoni Kitchen Ranges
What is the wattage for the halogen light for my hood?
Must be no greater than 30 watts. As it is a standard oven bulb I suggest you just remove the current one and bring it to a local hardware store.
Jul 11, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Bertazzoni hood replace bulb
First remove cover to access the bulb, pull bulb straight down being careful not to break it. to replace w/new bulb, remove bulb from package, be sure to use a cloth or some type of glove so as not to get oils from your fingers on the new bulb as this will create a hot spot on the new bulb and shorten the life of the bulb. Install the new bulb by inserting into the fixture by gently pushing the bulb into socket.
Hope this helps
Apr 19, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
NO POWER TO HOOD
Check gfi or breaker
Dec 10, 2013 | Bertazzoni Kitchen Ranges
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
Oct 02, 2009 | Kitchen Ranges
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Speed control on fan
It means that the filters on the hood need to be cleaned. You simply pop them out and can wash them in the dishwasher. Once clean, dry and replaced, you hold down the fan speed button (the second button from the left or " - " minus for more than five seconds.) When you first hit the button the A will appear, hold the button when the letter disappears, the timer has been reset until time for the next cleaning. The microprocessor in the system will flash every 30 hours of operation.
May 07, 2008 | Zephyr Venezia ZVE-E30 Kitchen Hood
Kitchen Ranges Logo
212 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
